06-26-2019, 12:06 PM | #1 |
25
Rep 108
2018 M40i Lighting Weirdness
OK, this may be in the manual, it may be in a thread on these Boards, but I've searched and can't come up with an answer.
For the second time (at least) the lights on my vehicle went crazy when I shut it off. Well, maybe not crazy, but the headlights, taillights, inside lighting and probably some others all came on simultaneously when I parked in my garage. My headlight switch is on off, I don't touch ANY panel switches after hitting the STOP button twice and taking my foot off the brake pedal. I have to basically turn the headlight switch to on and then back to off to get the lights to shut off. I THOUGHT that perhaps, the fob being in my pocket, I was somehow pressing a button as I moved about to get out, but I can't think of a button that will activate all the lights. They don't flash, there is no sound, the whole car, essentially, well, just lights up. Anyone experience or know of something similar? Thank you in advance. |
06-26-2019, 02:19 PM | #2 |
19146
Rep 8,031
Drives: 2024 X5 M60i
Why are you pushing the stop button twice when turning off the vehicle? Sounds to me you are turning it off and then turning it back on to a stand-by state.
Instagram: @Phxrisingphotography
Current - 2024 G05 X5 ///M60i in Java Green Past - 2005 E53 X5 3.0i in Titanium Silver; 2008 E92 335i in Montego Blue; 2019 G01 X3 M40i in Glacier Silver; 2022 G80 M3 Competition in Twilight Purple |
06-26-2019, 02:27 PM | #3 | |
25
Rep 108
While I appreciate your post, I think the issue I'm experiencing is unrelated to this procedure. Most of the time there is no problem with pushing the button twice. |
06-26-2019, 03:39 PM | #5 | |
25
Rep 108
I'll take the advice of you two posters and see what, if any, difference there is. Pressing the button once does indeed shut the engine down; as I say, pressing it again in addition seems to blank the display, so the second press does do SOMETHING. However, I still don't think this is related to the lighting flakiness. Thank you for the info regardless. |
06-26-2019, 04:28 PM | #6 | |
25
Rep 108
Thank You. |
06-26-2019, 04:33 PM | #7 |
926
Rep 2,046
Drives: X3 G01 30i xDrive
there is on off button for the lights? no..there is not... not in my X3. lights will stay on until certain amount of time or until you lock the car (whichever comes first).
'18 G01 X3 xDrive 30i xLine, Sophisto grey, Vernasca Mocha, Adaptive
06-26-2019, 05:02 PM | #8 |
25
Rep 108
06-26-2019, 05:10 PM | #9 | |
926
Rep 2,046
06-26-2019, 05:16 PM | #10 |
25
Rep 108
Perhaps there is a misunderstanding (again, I'm prone to those).
The issue I'm having is that, occasionally, when I stop the car and exit both the headlights and taillights (at least) go on, even though the rotary switch that controls the headlights (and some other lights) is in the off position. I would assume all models of X3 have this switch (I'm not talking about manually controlling DRLs or pathway lighting or other interior lighting, just headlights). In order to get the headlights and taillights off I need to rotate the switch to the headlight "on" (or headlight "automatic") position and then back to off. I hope I'm not confusing people. |
06-26-2019, 05:44 PM | #11 |
926
Rep 2,046
Thing is, that is not an issue, rather a behaviour. Completely normal. The lights are always on (DRLs, which includes the tail lights), no matter the switch position. The "off" position of the switch is turning off the adaptive mode of the lights (if you have them). I'm not confused - but it looks like you are Btw, what manual are you using? The phone app version is better imo, and tailored to you car options.
06-26-2019, 06:22 PM | #12 |
141
Rep 112
FWIW, I push the button once after placing the car the Park and taking my foot off the brake. If I leave my foot on the brake when turning off the car, the radio and other displays do not turn off when the door is opened. But that's been another mystery of sorts, covered in another thread, as I recall.
Good luck with diagnosing your problem! |
06-26-2019, 06:50 PM | #13 |
1456
Rep 3,931
BMW was smart to get rid of that stupid push the start/stop button twice to completely turn engine and vehicle off. They were also smart to go back to the normal turn signal activation like every other make has been using for decades and now only one pull on inside door lever to open the door when the doors were locked.
06-26-2019, 07:22 PM | #14 | |
25
Rep 108
Perhaps it is different in Europe, I don't know, but that's not how it works in the U.S. |
06-26-2019, 07:26 PM | #15 |
272
Rep 467
My radio suddenly stopped turning after opening the door(s) like it used to. Now it turns off when you lock it. Kind of annoying...maybe I'll try the two button off method.
06-26-2019, 07:31 PM | #16 | |
25
Rep 108
Hitting the STOP button twice hasn't done any harm (I don't think) so I guess it's up to the driver; choose whichever procedure gives the result you prefer. |
06-27-2019, 02:39 AM | #17 | |
Straight Six Convert
444
Rep 894
Drives: 2019 X3 M40i
2019 G01 X3 /// M40i in Carbon Black, 718M 21's, M Sport + Pack, Pano, F/Mirrors, Full Screen CarPlay Activated, ThinkWare F770 F/R DashCams, Gyeon Q2 Pure Ceramic Coated. PCW BackBox Mod
06-27-2019, 04:30 AM | #18 | ||
234
Rep 366
If you press the engine button to turn off the ignition (so the rev needle falls to 0 rather than 'Ready'), then open the door, it will stop the radio. However If you come to a stop, the ASS turns the engine off (needle on 'Ready'), then you put it in Park and open the door, the radio will keep playing for a while, or until you either a) open another door b) close the drivers door. I also thought this behavior had changed at first, but then realised it was because I was driving it in sport less often and the ASS when turning the car off instead of me pressing the button. Quote:
06-27-2019, 07:15 AM | #19 | |
25
Rep 108
Look, is it something I can live with? I guess so, although I've also had the rear hatch pop open while I was driving, that happened once but I can't live with that possibility. I'm just resigned to this car (cars nowadays?) being so computerized that gremlins pop up. Maybe what I should do is wait and see if it turns itself off automatically. But your idea is interesting, thanks, I'll look into it. |
