06-23-2019, 10:45 PM | #1 |
Rep 21
91 vs 93 octane
Check out the HP and Torque. Article in the new edition of Car and Driver.
06-24-2019, 11:04 AM | #2 |
153
Rep 427
Drives: 2019 M5 Competition
06-27-2019, 02:51 PM | #3 |
283
Rep 288
Drives: 2018 F90 M5
More torque with the lower octane fuel? Why would that be? This makes those of us who only get 91 feel a little better. This motor is seriously underrated by BMW. Likely around 660hp and 660lb/ft at the crank. Way more torque than advertised.
06-27-2019, 03:35 PM | #4 | |
4425
Rep 4,109
And as for 2.7s, I've only managed 2.8s even with the tune. It might require a prep'd surface I suppose. |
06-27-2019, 04:21 PM | #5 |
94
Rep 419
Drives: 2019 F90 M5B, 2006 E60 550i
So, what’s the deal with certain states not having 93 octane? Is it for some type of pollution control measure?
06-27-2019, 07:29 PM | #6 |
2274
Rep 3,300
I'd like to see a similar comparison with the Alcohol containing Gasoline vs Pure Gasoline. I like to get into discussions with people about simple numbers. With multiple cars I have tested MPG with and without the alcohol. In every vehicle tested (long drives) the alcohol containing fuel got about 10% less miles per gallon which means one burns MORE fuel to go the same distance with the alcohol added to the gasoline. (that is read - less environmentally sound).
So with the alcohol added what effect does it have on Hp? My experience was that with my RS6 and A8L (both turbo v8's, both over 450 hp), the cars were noticeably quicker on the Pure Gas. The kicker is you now pay MORE for the Pure gas per gallon when the first gas that came along with Alcohol was more expensive than the pure gasoline! I have put pure gas in my M5 once, but noticed it was only 91 octane so I did not fill the tank. I would rather use the 93 octane from other gas stations, but I have not read much on alcohol addition and it's effect on octane, ie. it's real effect, not the hype. I know ETOH engines can get crazy amounts of power, but from what I understand that is usually at higher RPMs than normal car engines. Mike
06-27-2019, 07:50 PM | #8 | |
37
Rep 56
Drives: 2018 M5
From my conversations with guys who race/track their cars regularly, many of them add about 3 gallons of E85 fuel to their tanks to increase to octane rating (read, more horsepower) and have the added benefit of the cooling effect of ethanol on their engines. For our F90 on a full tank of 91 octane (E10) mixed with 3 gallons of E85 is makes the total ethanol concentration 21% and octane 93.1. This is basically a "poor man's way" of increasing octane without paying $10/gallon of 101 octane race fuel. But I too would like to see the difference on a dyno as fuel as fuel economy for a stock car of: regular gas vs. higher ethanol gas (ie. E21) vs. race fuel (101 octane mixed with regular fuel 50/50 mix) |
06-27-2019, 08:08 PM | #10 | |
2274
Rep 3,300
Mike
06-27-2019, 08:10 PM | #11 |
4425
Rep 4,109
06-28-2019, 06:09 AM | #12 |
2274
Rep 3,300
