Rear Sway Bar Installed Finally . . . Pics
03-29-2006, 10:10 PM | #1 |
574
Rep 6,750
Rear Sway Bar Installation
Unlike with the e46, beware that the e90 factory rear sway bar cannot be removed without first lowering the rear sub-frame. This setup is similar to that on the Mini Cooper. However, in the e90, the exhaust and brake lines are just below the subframe. This job would take longer, but be less mechanically challenging if the driveshaft, exhaust and brake lines were removed first. Dan from International Dreamcars in Redondo Beach performed the install. I noticed several modified go-carts, a Porsche 914, two Maseratis and a Ferrari at his shop so I felt I was in good company with an experienced mechanic who was trusted by others.
Here are the photos: Last edited by ksfrogman; 03-30-2006 at 09:25 AM.. |
03-29-2006, 10:13 PM | #2 |
574
Rep 6,750
The subframe was dropped no more than a few inches. This allowed ample room to remove and install the rear bars.
03-29-2006, 10:17 PM | #3 |
574
Rep 6,750
Roll Bar Stiffness = C*D^4/(L*A^2)
C = a constant D = roll bar diameter L = length of bar A = length of lever arm Stiffness increases to the 4th power relative to incremental bar diameter increases. SWAY BARS: Stock F 26.5mm R 13mm Eibach F 28mm R 15mm H&R F 27mm R 20mm |
03-29-2006, 10:49 PM | #4 |
MAUI BUILT
485
Rep 7,781
Drives: 2006 330i MT
You got the H&R's right Michael? I look at that H&R rear bar and
How's the car feel now? Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
03-29-2006, 10:59 PM | #5 | |
574
Rep 6,750
After the springs and front bar were installed, I was a little disappointed that there wasn't an appreciable difference in handling. I could feel the road bumps ever so slightly more, and the car actually plowed (understeered). The major difference of course was the car's lower side profile. Remember, because of the unexpected difficulty with the e90 rear suspension, the rear bar installation was unsuccessful. I'm grateful for the rear sway bar install. The rear bar makes a huge difference! I'm so happy with it. The car feels lighter, is more composed and turns with less sway and fanfare--more like a luxury go-cart. Before when, say, making a quick sharp right turn, the right rear tail would pop up. Now the car turns as a unit without the unsettling forward and aft up/down movement. I'd be curious to do a timed slalom manuever comparison. This all makes sense as you can see from the photos and specs. The H&R front sway bar is only 0.5mm bigger in diameter than stock, but the rear increased from 13mm to 20mm, which gives a very noticeable exponential increase in stiffness. Last edited by ksfrogman; 03-31-2006 at 08:30 PM.. |
03-29-2006, 11:08 PM | #6 | |
MAUI BUILT
485
Rep 7,781
Danny
03-31-2006, 12:39 PM | #8 |
2148
Rep 10,176
Question ksfrogman: How long did the actual install take, from time of taking the rear wheels off to putting them back on?
Thanks in advance! It looks as though you have to take the springs out and then drop the rearward subframe by removing those two large carrier bolts. |
03-31-2006, 06:24 PM | #9 | |
574
Rep 6,750
03-31-2006, 06:28 PM | #10 |
574
Rep 6,750
Dan, the mechanic (seen in the 2nd photo), is down-to-earth, knowledgeable and fun to talk to. He was nice enough to take the install photos for me (I was away). I would highly recommend him to anyone in this area who needs this done.
Didn't have my camera at the time, so I used my camera phone. Here are a few other vehicles being worked on at the shop: Last edited by ksfrogman; 03-31-2006 at 08:33 PM.. |
03-31-2006, 11:04 PM | #12 |
75
Rep 1,440
I drove ksfrogman's car..I can say that it is much stable on turns..I REALLY LOVE THE RIDE!
can someone take over my car payments? I wanted to get a stick 330...arghhhh! why didnt I met you last october doc?!!!! |
04-01-2006, 01:09 PM | #13 | |
574
Rep 6,750
Thanks Stew
04-15-2006, 05:37 PM | #14 |
63
Rep 1,516
So frogman,
If you had to do it all over again...would you just get the rear and not the front? Because I am considering getting some sways, but the front seems kind of pointless if its just a bit thicker. Thanks bro |
04-15-2006, 07:54 PM | #15 | |
574
Rep 6,750
I would not change out just the rear bar, because of the risk of having too much oversteer. The car feels pretty balanced now. When you look at that formula I posted above, you can see how even a small incremental increase in roll bar diameter results in an exponential increase in stiffness (specifically to the 4th power). I don't like the feeling of dramatic body roll, and having both front and rear sway bars combined probably do a better job of minimizing roll than having any one of them alone. Mike, where in California are you located? |
04-20-2006, 11:56 PM | #16 |
34
Rep 776
Drives: 330i rec'd 2/17/06
Out of curiousity, would it be overkill to install front and rear sway bars, AND a strut bar?
JB | BBS CHs | Blacklines | HO40 | ACS Rep Roof Spoiler | H&R Sport | Hartge Rep Lip | OEM Strut Bar | M-Tech Rear
04-21-2006, 01:45 AM | #17 | |
574
Rep 6,750
I don't know how to more simply explain this. Okay, let's try this. Think of a fence made out of wood. It sways from side-to-side in the wind. You can reduce fence flex by strengthening the wooden crossmembers with metal L-brackets (analogous to your strut bar). Alternatively, you can prevent the entire fence from swaying in the wind by strengthening the fence foundation by pouring concrete around the posts (think sway bar here). How's that explanation? |
04-21-2006, 02:11 AM | #18 | |
MAUI BUILT
485
Rep 7,781
Danny
04-21-2006, 07:41 AM | #19 |
Good MAN....
21
Rep 483
Can I install the rear bar myself? I was thinking to do it myself, but it seems prety hard.
Parting out!!! sub, sub box, N2, and Module wheels. :rocks:
04-21-2006, 07:53 AM | #20 | |
//Mdicted
347
Rep 9,988
Drives: a Cop Magnet
Garage List 2009 e92 M3 DCT CF ... [10.00]
2015 S-Works Roubaix [0.00] 2013 Trek Madone 5.9 [9.50] 2012 Scott - CR1-Pro [10.00] 2008 e92 M3 6MT (Up ... [10.00] 2002 e46 M3 Cabriol ... [7.00] 2006 e90-325i (DD) [7.00] 2002 e39 M5 (retired) [9.50] |
Another fello in my similiar situation that did only the rears(20mm) and left his 25mm stock the same, and he felt a very unsafe oversteer during an emergency maneuver. He changed the 20mm to a less agressive 17mm to be conservative. Otherwise it would need to change the fronts too to 27.5mm to be mechanically tuned correctly. I just opted to do 17mm, to be in the middle of the spectrum and be safe, and the car handles correctly. for I dont want to change both.
04-21-2006, 11:00 AM | #21 | |
574
Rep 6,750
In answer to your question, you can probably do it, but understand that the safest way to tackle this involves removing your exhaust and brake lines first, but this would be a headache, and very time consuming. The other mechanic, Dan at International Dream Cars, left those in place, but he carefully lowered the subframe with a separate jack he kept in place to avoid damage to the components below. |
04-21-2006, 01:02 PM | #22 | |
34
Rep 776
