06-19-2019, 08:44 AM | #1 |
100
Rep 562
Offset Help?
Looking at:
19x9.5 et 20 F 255/35/19 19x11 et 45 R 285/30/19 I have been reading through some of the threads and some people go et 40 rear with a 19x11. Any input before I pull the trigger? |
06-19-2019, 09:36 AM | #2 |
565
Rep 1,092
11 inch ET45 rear will make the wheel 18mm closer to the inside compared to stock. I'm not sure if there is enough room.
Also I don't like that it would look uneven. The front is 15mm wider and the rear is only 7mm wider than stock (by wider I mean how it lines up with the fender. ET40 would be a better fit, fortunately it can easily be fixed by a 5mm spacer. |
06-19-2019, 03:27 PM | #3 | |
100
Rep 562
06-19-2019, 04:32 PM | #4 |
565
Rep 1,092
Please don't base your order just on my information. I don't have experience with putting 11" wheels on the M2 but other people in this subforum do. I just know that the stock setup needs 10mm front and 8mm rear to be perfectly flush (more on a lowered car)
