06-19-2019, 06:56 AM | #1 |
45
Rep 162
Tow capacity m40i
Hi,
I'm brand new to this forum and to BMW. I sold my 2014 WRX hatch and bought a 2019 X3 m40i. I'm waiting for it to be delivered. I have a question about towing capacity. Has anyone tried towing a small car with the m40i? I have a Honda S2000 that I'm hoping to tow around 450 miles every so often. I ordered the m40i with the factory tow hitch. My question is a) is towing a car a good idea with the m40i? b) do I need anything special beyond the factory hitch to do so? The Honda weighs 2900 lbs or so and I think I've read that it can tow around 4400 lbs. Thanks all! |
06-19-2019, 07:44 AM | #4 | |
45
Rep 162
06-19-2019, 08:02 AM | #5 |
Exalted Tire Scorcher
35
Rep 91
A controller is a REALLY good idea on anything over 2000pds, the only good way to stop a trailer that starts swaying is a burst of trailer brake pressure. The X3 is supposed to have some dynamic stability features for settling down trailers but I still wouldn't skip a good controller.
Each state/province has different rules on the max unbraked trailer weight. My understanding is that the wiring is already there it just needs to be connected from under the dash to a brake controller. https://www.youtube.com/watch?v=cfEt4Ja111w Plus tow a car on a low trailer, not the one in the video that puts the CG 3ft in the air.
Now: 2019 G01 X3 ///M40i Graphite Metallic
Sold: 2012 535i, 2009 328i |
Crypto2k344.50 |
06-19-2019, 11:18 AM | #6 |
66
Rep 105
My Camaro is 3020 lbs + trailer 1530lbs. Tongue weight 460 to 475 lbs.
Tows great with a weight distribution hitch. ---Bill. |
06-22-2019, 10:48 AM | #7 |
170
Rep 445
Drives: 2018 X3 M40i
Location: Milky Way, Earth, North America, Arizona more specifically.
09-05-2022, 02:47 PM | #10 | |
Retired Curmudgeon
2985
Rep 4,047
You can get wireless ones, but I have hard that they can be difficult to pair sometimes with our vehicles (BMWs). Pairing when hooked to a friend's pickup and then moving over to the X3 is one way to make them work if you run into this problem. With the factory tow hitch and wiring, you also get the coding that has the DSC working with the understanding that there is a trailer back there when the 7 pin connector is in use. Very handy though with the short overhang, unless you don't load your trailer correctly, you shouldn't need it to intervene except in an emergency.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
09-05-2022, 03:45 PM | #11 |
83
Rep 163
I tow a 3,600lbs travel trailer with the X3.
Would highly recommend the Curt Echo wireless brake controller. Works perfectly if you remember to turn the daylight running lights on first, plug the Echo into the car second, lastly the trailer plug into the Echo socket. If you reverse the second and third step, it doesn't pair. The specs of the factory hitch are 4,400lbs max, 440lbs max tongue weight and the door sticker for payload which should be north of 900lbs, really nice for a vehicle of this size. Last edited by FredBa; 09-05-2022 at 04:45 PM.. |
09-05-2022, 04:20 PM | #12 |
849
Rep 1,858
Towing capacity is on the VIN plate on the RHS (driver side in the UK) door shut.
My 2018 x3 m40d towing capacity is rated at 2000kg, I.e difference between 2550kg laden weight and 4550kg total train weight with the aftermarket detachable Tow hitch rated at 100kg nose weight |
