Wastegate out of adjustment?
06-18-2019, 09:59 PM | #1 |
Rep 96
Hey guys I just recently fixed my boost being way undertarget with a new boost solenoid. At first I was overboosting a bit but after driving it a bit now I'm underboosting 1-2 psi. Do you guys know if the dme adjusts the wastegate through adaptations at all? I'm thinking maybe my wastegate is out of adjustment manually?
What do you guys think? Thanks Btw my car is a 2011 335xi n55 mhd stage 1. |
06-19-2019, 12:07 AM | #2 |
166
Rep 429
Drives: 2011 e92 335xi
How? Did you replace turbofold?
2011 E92 335i xDrive
Pure Stage 1 | DV+ & Inlet | Injen Intake | M3 Cowl | ETS 5" FMIC & CP | Aquamist HFS4 Direct Port | CSF Radiator | Wagner Catted DP | BMW PE | Apex FL-5 | Michelin PS4S | 335is Engine mount | SDW Monoball thrust arms | UUC Swaybars & SS Brake lines | Bilstein B8 | Dinan Springs & Shock mounts | Whiteline RSFB | M3 Rear Control arms | Manzo Toe arms | Wavetrac LSD |
06-19-2019, 08:24 AM | #3 | |
719
Rep 1,753
On PPK tune i am right on target to the 0.02 PSI with OTS by twisted tuning always off target by 1-2 psi or more. |
06-19-2019, 05:36 PM | #4 |
Rep 96
My boost was perfect at first so there was a definite change car feels different. Also my boost is undertarget at all rpm ranges not just wot.
