Bimmerpost
4 Series
Technical Topics iDrive, Nav, Phone, Audio, Video, Cameras, Electronics Parking Assistance Front camera question
      06-16-2019, 06:14 PM   #1
Cosmo_Kramer
166
Drives: Lexus
When the car is in Drive with front bumper camera turned on does the camera image turn left or right when steering wheel turn? I’ve seen this in X5 not sure G20 does the same?
      06-16-2019, 10:00 PM   #2
xraymd
xraymd's Avatar
Drives: 23 M2, 22 Lincoln Navigator
No, it doesn’t
      06-16-2019, 10:22 PM   #3
Cosmo_Kramer
166
Drives: Lexus
Originally Posted by xraymd View Post
No, it doesn’t
What about backup camera?
      06-16-2019, 11:09 PM   #4
DomiGijzen
DomiGijzen's Avatar
Netherlands
70
Drives: BMW iX3 MSport High Exec (G08)
Backup camera does indeed rotate when in parking mode.
Edit: checked this morning, this also count for front in parking mode.
I'm talking about the view on the screen. The camera itself is fixed and doesn't rotate.
Grz D.!
      06-17-2019, 09:49 AM   #5
Cosmo_Kramer
166
Drives: Lexus
That's good to hear. Yes, just the image rotation not the actual camera that's a cool feature because you can see around the corner.
      06-17-2019, 09:51 AM   #6
DomiGijzen
DomiGijzen's Avatar
Netherlands
70
Around the corner as almost 90 degrees to left/right to check for traffic? There is also the regulate camera view which has an almost 180 degree view which I use for that.
Grz D.!
      06-17-2019, 10:00 AM   #7
Cosmo_Kramer
166
Drives: Lexus
Yes, when I test drove it I can see the corners on both front and back camera due to wide angle. Especially for backup camera when the wheel turns you should be able to see the corners better for pedestrians and oncoming cars.
      06-17-2019, 10:51 AM   #8
xraymd
xraymd's Avatar
I’m wrong. I hadn’t noticed it before but front camera view turns when you really crank the wheel.
      06-17-2019, 06:13 PM   #9
golferboy2312
Drives: 2020 M340i xDrive
Isn't there a "wash view" that will show your tire track when you want to pull into a car wash?
      06-17-2019, 06:17 PM   #10
phillyd2
216
Drives: 2020 M340i XDrive
There sure is.
Search this Thread:
Advanced Search
g20
