Bimmerpost
4 Series
Technical Topics Cosmetic and Lighting Modifications (exterior & interior) vicfalc09 | Shadow line gloss black front bumper accents installation
      06-15-2019, 09:10 AM   #1
vicfalc09
vicfalc09's Avatar
211
Drives: M340i xDrive
Today I figured out how to swap out the cerium grey front bumper air duct trims with the gloss black shadow line trim pieces. Thanks to PARTS@STBMW for the parts.
Using a plastic trim tool locate the clips that hold the trim piece in place. I started at the bottom inside clip working my way up. When I did this I got the first two on the inside loose and this also loosened the outside two. The top inside one will be the last one attached. Slowly pry away from vehicle ensuring not to damage paint/plastic. The top tab may come off clean or it may break. Didn't matter to me as I purchased the gloss black pieces. I broke one and the other stayed intact. See photo of clips and finished below.
[IMG]
View post on imgur.com
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
BMW HIGH-GLOSS BLACK FRONT TRIM
https://www.bmwpartspros.com/partloc...catalogid=8798
Appreciate 5
      06-15-2019, 01:21 PM   #2
evo2335
Drives: G37 IPL (340i on the way)
Nice write up Vic. Kinda random, but you have pics of the tools that worked best for this? My trim should be coming in soon and I need to do this ASAP, lol. The cerium bits gets dirty way too easily
      06-15-2019, 01:25 PM   #3
vicfalc09
vicfalc09's Avatar
211
I used a couple pieces from this kit:
MATCC Car Panel Removal Tools Kit... https://www.amazon.com/dp/B07C7D1JND...p_mob_ap_share
      06-16-2019, 09:26 AM   #4
miked1999
Drives: 2020 M340i
2020 M340i  [0.00]
Thanks Vic!
      08-16-2019, 12:47 AM   #5
joepimentel
joepimentel's Avatar
76
Drives: 2020 M340i
Hey Vic. Can you help me understand exactly how you did this? I bought the same plastic tool kit that you referred previously on this thread, and tried to pry the piece away as you explained but with no luck.
Did you wedge one of the plastic tools between the actual bumper and the intake accent at the location of the clips? If so, did you pry and put pressure towards the bumper or towards the accent? I'm afraid I'm going to break something -- especially the mount that the clip clips into.
I was able to follow your guide on removing the mirror caps but I'm stuck on this one. Any additional help you can give would be greatly appreciated.
      08-16-2019, 12:48 PM   #6
vicfalc09
vicfalc09's Avatar
211
Wedge the plastics tool between the bumper and the clips (careful to not scratch the bumper) at the location of the clips and press forward. Each clip should pop.
      08-16-2019, 01:47 PM   #7
joepimentel
76
Drives: 2020 M340i
Ah, just wedge it in and push in towards the vehicle?
      08-16-2019, 01:49 PM   #8
vicfalc09
vicfalc09's Avatar
211
Yes
      08-16-2019, 01:50 PM   #9
vicfalc09
vicfalc09's Avatar
211
Yes
Start at the bottom inside, I broke a couple clips on the cerium Gray piece on one side, but didn't matter as I bought the black replacements.
      08-16-2019, 01:54 PM   #10
hubbahubba
hubbahubba's Avatar
8793
Drives: M3CX
So to clarify, you did this from front of car, not from behind?
      08-16-2019, 01:56 PM   #11
vicfalc09
vicfalc09's Avatar
211
Correct
      08-16-2019, 01:58 PM   #12
vicfalc09
vicfalc09's Avatar
211
Correct
See numbering start at 1
hubbahubba8792.50
      08-16-2019, 03:03 PM   #13
hubbahubba
hubbahubba's Avatar
8793
Drives: M3CX
Awesome, thanks!
      08-23-2019, 03:56 AM   #14
ParrotBro
ParrotBro's Avatar
25
Drives: BMW 3-Series since 2004
I wish I was that brave when I get my car lol
      03-05-2020, 02:55 AM   #15
kevinyao1027
Drives: M340i
Correct
I can get the first clip out, but the second one is just hard for me...the distance between the accent and bumper is just too close I can hardly squeeze my tool in and even if I pushed really hard on the clip I was not able to pop it out..
g20
