CIP21 Heads Up
03-29-2006, 03:09 PM | #1 |
Senior Member
Rep 91
CIP21 Heads Up
Having CIP21 loaded today.......278 mins to load according to the BMW center computer.
Just thought you should know it's going to tie up your car most of the day. Since the software is still loading, I have no information on what it fixed or broke. |
03-29-2006, 03:14 PM | #2 |
Moderator
318
Rep 17,767
Drives: F36 428i,E90 328i, E85 Z4 3.0i
Any new features? Was CIP21 installed on your car to fix a problem/issue or your SA hooked you up...please keep us updated. Thanks
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call! |
03-29-2006, 03:23 PM | #3 |
Senior Member
Rep 91
Actually just took the car in for a few minor (non-software) tweaks.
The service technician and I were just talking when I mentioned CIP21. He said that he would put it on if I wanted. I figured why not. SA only arranged for a loaner after being told of the time delay. |
03-29-2006, 03:34 PM | #4 |
364
Rep 5,842
Drives: 2006 325xi
awesome, ask them if there are any major / minor changes with it
03-29-2006, 11:54 PM | #5 |
Senior Member
Rep 91
CIP 21 was finally installed. Took over 5 hours.
Below is a list of the E90 corrections: 1) The stored station list is intermittently empty on CCC equipped vehicles. However it is still possible to change stations using the steering wheel buttons. (CCC is Computer Communications Center) or iDrive 2) CCC Navigation displays incorrect vehicle position. Refer to SI B84 10 05. 3) CCC: Audio switches off briefly for 5 seconds with RDS active. Refer to SI B65 26 05. 4) After programming the CCC with CIP 19.x or Progman 20.x it is not possible to store radio stations. 5) The battery is dead. During "Energy Diagnosis" the JBE (Junction Box Electronics) is identified as the "sleep mode preventer". Only concerns vehicles with Comfort Access (SA 322). 6) When the vehicle is double-locked from the inside using the remote control key and the occupant moves, the alarm is triggered. Only concerns vehicles with Comfort Access (SA 322). So far so good. Needed to reset all presets and reacquired bluetooth. If you want CIP 21, you will have to let your SA know that you have one of the above problems or they most likley will not authorize the update. |
03-30-2006, 12:08 AM | #6 |
your average JAMF
3115
Rep 4,095
Drives: '21 M2 Comp, '19 Golf R
How could BMW modernize SO much of the eletronics in the car - witness the new fiber optics for instance - and still have some 1982 cheeseball serial connection to upload software updates? That can't be THAT much data, I'm guessing they do some Xmodem-type 9600 bps serial transfer that is just slower than molasses. NO excuse not to have a simple USB2 or Firewire interface for uploading.. would take minutes, not hours.
'21 M2 Comp
'19 Golf R |
03-30-2006, 01:10 AM | #7 |
Senior Member
Rep 91
From what I understand. it not as simple as updating programs on a hard drive. It is more like updating the eprom of every computer chip in the car. From what I was told, all modules must be updated to the same relative revision so that internal communactions can take place.
A faster delivery system might improve the process, but I suspect not much. Nevertheless, 5 hours is insane. |
03-30-2006, 06:51 AM | #8 |
Rep 64
BMW "Ultimate Technology Machine - NOT"
No doubt my 325xi is the best car I have ever driver, however, the electronics are hardly worthy of "German engineering". From a failed oil sensor, ghost like warning lights for "SOS" BMW assist to terrible owner manuals and, at best, indifferent BMW Assist you sometimes wonder is you purchased a Hyundai or a BMW. Also CIP 20 should have been handled by a general recall instead of by "Customer Complaint Basis". Sorry, a bit off the subject but a bit related.
04-02-2006, 11:08 PM | #9 |
My other ride gets 2000 nm to the neutron...
Rep 54
Did CIP 20 eventually start going on at the factory? I ask because, although I just took delivery a week or so ago, I am having the Bluetooth problems normally associated with the lack of CIP 20 update. Am I nuts?
330i / Premium, Sport, and Cold Weather Packages |
04-03-2006, 05:58 PM | #10 | |
Rep 64
CIP 20
04-05-2006, 09:53 AM | #11 |
15
Rep 88
good info and thx. someone has a SB on all fixes ?
TIA. M
MY '06 E91 325i Touring "High Executive" and MY '06 E81 130i "High Executive" Color: Monaco Blue, Interior: black Dakota leather, Transmission: manual 6-speed Other options: sportsuspension, AFS, (panorama) sunroof, M-Sport headlining, Bridgestone Potenza RFT, ACC, LOGIC 7, PDC, foldable mirrors, ski-bag etc. etc. etc.
04-05-2006, 09:29 PM | #12 |
20
Rep 374
Drives: '05 645Ci Coupe
They added an item here (#7)
The following software errors were corrected with the release of Progman 21.00.00 (Target data Status E89x-06-03-510). 1) The stored station list is intermittently empty on CCC equipped vehicles. However it is still possible to change stations using the steering wheel buttons. 2) CCC Navigation displays incorrect vehicle position. Refer to SI B84 10 05. 3) CCC: Audio switches off briefly for 5 seconds with RDS active. Refer to SI B65 26 05. 4) After programming the CCC with CIP 19.x or Progman 20.x it is not possible to store radio stations. 5) The battery is dead. During "Energy Diagnosis" the JBE (Junction Box Electronics) is identified as the "sleep mode preventer". Only concerns vehicles with Comfort Access (SA 322). 6) When the vehicle is double-locked from the inside using the remote control key and the occupant moves, the alarm is triggered. Only concerns vehicles with Comfort Access (SA 322). (New) 7) CCC: Loss of audio in all modes. Vehicles equipped with Top-HiFi. Refer to SI B65 02 06. Also look for Other CIP release info in this forum for more CIP lists. I no longer post the whole list as all the older ones are repeated each time. 20, 19, 18 and 17 are all here somewhere |
04-06-2006, 01:06 AM | #13 |
15
Rep 88
04-06-2006, 07:19 AM | #14 | |
20
Rep 374
