06-04-2019, 11:06 PM | #1 |
1699
Rep 2,609
Ok, as I have time (so irregularly), I am going to collect in a somewhat organized way some of the bugs I am seeing using videos, pics, and descriptions. Each of these bugs, issues, concerns, confusions, etc. will be tagged and each will generally be forwarded to BMW simultaneously with being posted here, both to BMW Canada while they are still talking to me as well as to my excellent local Waterloo, ON, Canada BMW dealer ... so this won't be just us bitching to each other here.
Here are the first videos, they are pretty self-explanatory. 20190604-01 on 3/2019.45: 20190604-02 on 3/2019.45: 20190605-03 on 3/2019.45: 20191216-01 on 11/2019.40: Does not switch to forward camera when placed in Drive (at low speed!): 20191216-02 on 11/2019.40: Does not switch to forward camera when placed in Drive at low speed, BUT then switches to forward camera as one drives a few 10s of meters or higher speed! |
06-05-2019, 01:18 AM | #3 |
50
Rep 91
Great constructive feedback instead of plain b****ing. Kudos to you for sharing and simultaneously sending these out to BMW. Hopefully such feedback will be appreciated by them and they fix these s/w issues in the coming updates.
06-05-2019, 06:59 AM | #4 |
313
Rep 1,448
Perhaps I am not fully alert at this point, but am not sure that #2 & #3 are ‘bugs’.
You obviously have Waze set up to alert like a cell phone call so that takes over the screen. There are times this is welcome, but the problem as I see it is that Waze does not give us better options. I say this as someone who puts my iPhone X into the charging tray with Waze open which means I have to clear Apple Pay several times a trip. In terms of #3, I think even my F15 was the same. If I want forward camera I have to press the Parking cameras going in. If I stop and reverse then I must repeat the process. I do not know the logic behind this maneuver but it is consistent.
2019 BMW X5 xDrive 50i M Sport: ZD8/ZLS/ZMP/ZP2/ZPK/ZPX/337/ZX7/2NH
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired R360c + EL, V1G2 + V1Driver, Uniden R8 |
06-05-2019, 07:41 AM | #5 | |
1699
Rep 2,609
For 20190605-03, if you start this sequence by REVERSING, it all works correctly — rear camera on when in reverse, front camera on when in drive automatically. But when you start as shown in the video, it fails to autoswitch to forward camera in drive. Other cars do it right, although I've only driven a couple of other cars with front cameras. It doesn't matter if BMW did it wrong in other models as well. So yeah, a bug. One might ask what the logic should be instead: a) most cars are simplistic: switch to forward camera whenever gear is shifted to drive, switch to reverse camera whenever gear is shifted to reverse — that works well; or b) for a bit more sophistication, but at a risk of more corner cases, same logic they've already used elsewhere: switch to forward camera whenever gear is shifted to drive AFTER gear was just in reverse.
G05 X5 x40i (04/2019 mfg, Canada) on S18A-19-11-540
06-06-2019, 01:19 PM | #6 | |
18
Rep 72
My car is out for PPF and have only had it two days so I honestly don't know. Really appreciate the videos!! |
06-06-2019, 03:30 PM | #8 |
1699
Rep 2,609
Assuming you're referring to bug 20190605-03, it never [COLOR="DarkRed"]automatically[/COLOR] switches to front camera. It does time out with speed and distance (as default and as can be adjusted/coded with BimmerCode), and you can manually press the PDC button to eventually manually get the front view, but it never [COLOR="DarkRed"]automatically[/COLOR] switches to front camera in that use case.
10-12-2019, 03:31 PM | #9 | ||
134
Rep 326
10-21-2019, 09:01 PM | #10 |
12
Rep 33
Hi LexxM3. The first bug isn’t really a bug as much as UI design weakness. By choosing the camera view on the hood of the car (with the A on it) you’re selecting the “Automatic” option where the view changes based on the driving situation (e.g. how the view changes when you pull into a parking space or garage). To change to the front camera, use the other camera button next to the shifter (the one without a light next to it) and make sure you’re in drive/driving forward.
12-12-2019, 07:36 PM | #11 |
1699
Rep 2,609
20190604-02 appears to be fixed on 11/2019.40
12-16-2019, 08:17 AM | #12 |
1699
Rep 2,609
Updated first post with a couple of new camera switching bugs videos now on 11/2019.40.
