06-04-2019, 11:35 AM | #1 |
Rep 21
Tyre pressure for 20" run flat tyres
Hi all
What tyre pressures are people using, i'm hoping i am running the right amount for the load i am carrying: Two adults and two teenage boys. Does 40psi seem a bit high to you? Thanks! |
06-04-2019, 12:30 PM | #2 |
148
Rep 277
Drives: 2019 X2 M35
do UK cars have a sticker in the driver's door jam? in the US that sticker has the proper tire pressures otherwise I would look in the owner's manual
06-05-2019, 08:39 PM | #3 |
66
Rep 159
My sticker says 32psi, but dealer put 40psi, it jumps like hell over rough surface, I lowered it to 32 and is now much more acceptable.
06-05-2019, 09:12 PM | #4 |
180
Rep 375
Drives: 2020 M2C DCT
I recall reading somewhere that the pressure is supposed to be 40 psi. I checked on the door pillar and it says 39. In general, you should not go lower than the pressure on the door pillar.
06-06-2019, 11:31 AM | #5 |
Rep 21
40psi all round, just seems like a bit of a high figure. When i got the car each tyre had a different tyre pressure reading ranging from 32 to 37.
If you have a lower than recommend tyre pressure you'll increase drag and you'll suffer from a higher than normal fuel consumption. Thanks |
06-10-2019, 10:11 PM | #6 |
Rep 44
My sticker says its 2.4bar (34.8 psi) on the front and 2.6bar (37.7 psi) on the back if the car is only carrying 1 passenger and 1 driver.
However, i set mine to 34 all around and it feels perfectly fine. |
