PDC retrofit question
06-04-2019, 01:38 AM | #1 |
9
Rep 88
So after much issues I’m finally to installing my retrofits I just did rear PDC on a 2010 328i sedan all wired in module was flashed and vin updated on winkfp inpa shows it. Updated my VO and fa_wrote it to CAS and NFRM shows up correctly went to Proccess the car to vo settings and I get a error on mulf, so I tried just doing the PDC worked fine. Went to the 2URAD and can’t read it, I’m assuming I need datens?
I believe I’ve read somewhere others have had luck processing a car using SG_Reset? Would that work in my case being I’m adding the PDC |
06-04-2019, 06:18 PM | #2 |
185
Rep 780
Rule of thumb is not a good idea to process the entire car and default code them. Should've only coded CIC and CAS from my understanding after adding the VO. Go to bimmergeeks.net/downloads and download e89 datens. Use bmw coding tool to update it and then try coding
06-05-2019, 12:20 AM | #3 |
9
Rep 88
Yeah I believe I’ve read that the usb kdcan cables have a issue with the most, I’m not using a icom using a bcable and it’s been pretty well, I guess I’ll re download my e89 datens see if I can connect to the 2URAD module I know there’s a line in there for PDC. I’ll have to look in the CIC have not yet,
06-06-2019, 10:25 AM | #4 |
9
Rep 88
No CIC module, checked the coding in CAS no options for PDC, still get a error for 2URAD... I guess I should know there’s no CIC I don’t have one hah.. all of my reset coding went fine i just an read the 2URAD to change it so the PDC uses the stereo speakers. Is a icom cable my only route?
06-06-2019, 12:32 PM | #5 |
9
Rep 88
Found a local shop with a alltell system that said he thinks he might be able to code the 2URAD but said if he couldn’t he’s still have to charge. Anyone know anything about alltell system coding? Would it work to add the PDC to the radio?
06-07-2019, 05:19 AM | #6 |
654
Rep 1,893
I believe (I've read but do not have personal experience) that you can only program/code RAD directly using ICOM (i.e. through the MOST bus). However, you can still alter the coding of RAD indirectly by changing the VO.
06-28-2019, 10:12 AM | #9 |
9
Rep 88
Got it was due to aftermarket amp system installed in car. Radio had to coded to hifi and some slight alteration of wiring into a JBL ms8 sound now works. Thanks for the help guys
