05-29-2019, 01:29 AM | #1 |
Built Motor F30 340i
403
Rep 257
What is the max power for the stock turbo so far?
What is the easiest way to get 450whp-500whp from the B58? And is it even possible with the stock turbo? Who would you recommend for a custom MHD tune? I'm currently leaning toward Wedge Performance as they are the only ones I know of that will tune the B58 for MHD.
My current mods are VRSF 4.5" Catless DP, Remus Axleback (just ordered), and having an exhaust shop make me a custom midpipe. I'm on MHD E30 Stage 2 currently. |
05-29-2019, 02:47 AM | #2 | |
Bmw340i Mppsk, bm3 tune,vrsf downpipe dinan intake
96
Rep 176
05-29-2019, 03:49 AM | #3 |
403
Rep 257
05-29-2019, 08:05 AM | #4 |
Cheapskate
4450
Rep 4,993
It seems we'll be able to reach that with e85. most stage 2 dynos are around 420whp. e85 gives you another 40-50hp.
idk about MHD, but BM3 has a couple tuners doing custom e85 tunes. |
05-29-2019, 10:16 AM | #5 |
558
Rep 1,457
This is the max power i seen on stock turbo with no meth and down-pipe so far.....
https://www.n54tech.com/forums/showthread.php?t=57432 No flash tune has achieved these numbers with the stock down-pipe. With meth it should easily be a 500whp car if tuned correctly through the JB4.
2024 X3 M40i
2014 BMW M5 |
05-29-2019, 04:58 PM | #7 |
62
Rep 132
Drives: OG M2
Define "spooling like crazy". Are you worried about # psi your turbo is making, IATs, manifold pressure...?
M2 - TC Kline DA Coilovers - Apex SM-10s - 265 RS-4s - Dinan Intake - BM3 - CSF Intercooler - VRSF CP
Previous: 6th Gen Camaro SS 1LE | 2020 JLUR Wrangler | F30 340i | B7 Audi A4 APR Tuned | E46 330ci Instagram @track.n.trail |
05-30-2019, 10:40 PM | #8 | |
403
Rep 257
05-31-2019, 06:54 PM | #9 |
62
Rep 181
Running 456whp/470tq with stock turbo on a stage 2 tune and meth with e85/91 blend. The tuner said we can probably 475-500 eventually but we’re already almost maxed out at 22.8psi
06-01-2019, 02:34 AM | #10 |
403
Rep 257
What tuner? And if you don't mind could I possibly see some of the logs? I'm curious.
06-01-2019, 02:38 AM | #11 |
62
Rep 181
I don’t have the logs but the tune was done by Alex at mission performance running their stage 2.5 flash with stage 1 trans flash. I mix 3.5 gal of e85 with 91 and run a 50/50 meth blend via the bms meth kit with an aftermarket HPC meth controller
06-01-2019, 02:51 AM | #12 |
403
Rep 257
Gotcha, solid numbers man. Have you taken it to the track?
