BMW M5 F90 (2018+) General Forums Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls    Spark Plugs
      05-26-2019, 07:29 PM   #1
Who's on first
Who's on first's Avatar
Drives: A-10C
Spark Plugs
So, my car is misfiring above 5k or so. Seems my plugs are due for replacement. Over 18,000 miles, with track days and tuned.
I could not find a thread on this yet.
I was told to get NGK SILZKBR8D8S ... can anyone confirm this, or have another opinion?
Thanks
      05-26-2019, 08:12 PM   #2
Used2be
Perennial PFC
Used2be's Avatar
Drives: F90 M5 DG/Aragon
The NGK equivalent number for that is 97506 which is what I used for the motor in the F10 M5. The engines are very similar, should work, but I have no experience yet with the F90 motor. Perhaps be safe and check with your tuner?
      05-27-2019, 06:01 PM   #3
hilsman
115
Drives: F90 Competition
Go to Burger Motorsport site. They have correct 2 heat range colder plugs for tuned F90 engines.
      07-19-2019, 01:49 AM   #4
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
F90 uses different spark plugs than F10 M5, i would stick with oem for now or have the dealer change them
https://www.bm3tuning.com/f90-m5/f90...boschzr5tpp320
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      09-04-2019, 11:41 PM   #5
JK-M5
JK-M5's Avatar
United Kingdom
61
Drives: MBB F90 M5
Dealers will charge you a small fortune to change the plugs out, go buy a spark plug socket and do it yourself, really easy to do. only take you 1hr, plugs will require to be gapped if the car is tuned to 0.018
F90BSM568.50
      12-12-2019, 02:17 PM   #6
marcvtec
407
Drives: M5
Can anyone confirm spark plugs need to be done at 22,000 km. ?
Did an oil change at my local guy and once he hooked up to the ecu to reset the service interval, his computer said they should be done as well as air filters.
We didn't bother but wondering if BMW would have done them ?
Seems too early imo.
      06-20-2020, 03:34 PM   #7
REF90
Drives: 2019 F90 M5
I had a similar situation today - brought the car to the dealer for annual state inspection and they recommended changing the spark plugs in the next few months. Car has 13k miles on it. It’s a covered cost so I was considering letting them do it, but I was surprised the car is calling for it (maintenance manual also says 30k miles before spark plugs should be changed). Are others still hearing of replacement spark plugs this early? Any issue having them replaced early? Car is amazing...hate to let the dealer have it for a day for unnecessary maintenance.
Thanks
      06-20-2020, 04:39 PM   #8
marcvtec
407
Drives: M5
My dealer replaced plugs, oil, cabin filter, and air filters at 25KM, as a reference.
Seems like that will be the interval for this car.
Even though i change oil every 7,500KM.(indy shop) between the BMW changes.
      06-22-2020, 08:36 AM   #9
BimmerM5C
75
Drives: 2019M5C F90
Thanks
Trade it lol
      07-03-2020, 10:19 AM   #10
DocWeatherington
DocWeatherington's Avatar
Drives: F90 CP
23 Bmw M3  [10.00]
Thanks
https://www.getbmwparts.com/oem-part...QtNGwtdjgtZ2Fz
Appreciate 2
      07-15-2020, 08:11 AM   #11
sollomon
Drives: M4,M5,M8C,X5M50I, X5M
2020 BMW X5M50I  [0.00]
2020 Bmw m8 competi ...  [0.00]
2018 BMW M4  [0.00]
2018 BMW M5  [0.00]
i had same issue and took the car to dealer and they gave me a middle finger with a quote asking 1800. i asked for break down and they said 400 for part and 1400 for labor. so i just towed the car home and changed the sparkplug to ngk but tbh i think oem is better. you can use ngk if your planning to run e85 on it. Your misfire will be fixed but after little bit you will face a major issue. i will upload the video later when i have time
      07-18-2020, 07:08 PM   #12
JBA87
107
Drives: 2019 BMW M5
What major issue is created?
      10-18-2020, 08:47 PM   #13
taw6189
Drives: BMW M5, 720s, 599
I just had me sparked plus cleaned after taking my car in for an oil change at 17k miles. Is it normal to clean the spark plugs instead of replacing them?
      10-18-2020, 09:52 PM   #14
DrHeLpErZx
DrHeLpErZx's Avatar
Drives: 2018 BMW M5
No, it's not normal to clean spark plugs. Normally when there's misfiring or signs the spark plugs need to be swapped, they get swapped.
Why go through the hours of labor removing the spark plugs to not replace the $10 a piece part.
      10-18-2020, 10:14 PM   #15
taw6189
Thanks, thats what i thought too. Service invoice says spark plugs were cleaned lol i think thats an error.
