XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > X1 DIY (Do-It-Yourself) Discussions
Register FAQ Calendar Today's Posts
      05-21-2019, 07:33 PM   #1
dustobub
Drives: None
Manual transmission swap for the N55
I've seen a couple posts musing about the possibility, but has anyone actually confirmed which part numbers would be needed, and if it's possible at all?
      05-25-2019, 11:54 AM   #2
themishmosh
36
Drives: BMW X1 xDrive35i
I would say, don't do it. Not worth the expense. And when you go to sell, nobody wants a Frankencar.
X1 35i, H&R springs, Bilstein HD shocks, BMS JB4, BMS chargepipe, xHP trans flash
      05-25-2019, 05:20 PM   #3
dustobub
Drives: None
I understand the pros/cons of doing a swap. I'd just like to know if anyone has actually looked into doing it.
      07-04-2019, 09:28 AM   #4
darkrom
darkrom's Avatar
Drives: 135i
Its always possible to manual swap anything it just comes down to do you have the right skills or a shop that does, and a HUGE budget in most cases it's more expensive than just buying the car you really want.
      01-11-2020, 04:34 AM   #5
djeieidhds
run it
Oman
Drives: dhudeuehhrhdhehee
I would love to see this done, possibly have a thread about switching to a manual gearbox for daily driving! Everything is basically bolt on, I would personally do it myself if living expenses never existed.
      04-16-2022, 03:50 PM   #6
thecodefather
It's S "A" V !!
10
Drives: 2014 X1 xDrive35i MSport
Has this been done yet? Still no threads to be found on the topic other than this one.
      04-17-2022, 10:05 PM   #7
Botlfed98
16
Drives: X1
buy a 3 series...
      04-18-2022, 06:19 AM   #8
4_ring_circus
14
Drives: Corrado, Audi S4, X1 128xi
X1s in Europa are available in manual, I'm not sure which engines. So if you gather all the parts, it should be a bolt in swap. There will be coding involved, wiring etc.
xbimmers
