JL XD600/6 Tuning
05-20-2019, 03:36 PM | #1 |
218
Rep 576
JL XD600/6 Tuning
I decided to do what I was advised to do in the first place and pulled the trigger on a 600/6 to replace my 400/4. Now that I have this better amp, what should my filters (generally) be set to (high passed/ low passed at how many hz)? My 400/4 only went up to 200Hz and the 600/6 goes up to 500hz. Thanks!
05-20-2019, 04:30 PM | #2 |
1918
Rep 13,117
The same as the old one set the rears doors/rears to the same thing
as the front doors. The gain will be the only thing that is different . If you still have the stock speakers you will need minimum gain and still probably have to fade out the rear to a large extent. Rear speaker are not really recommended by the stereopfiles here. Last edited by ctuna; 05-20-2019 at 04:35 PM.. |
05-20-2019, 04:51 PM | #3 | |
218
Rep 576
05-20-2019, 06:19 PM | #4 |
1918
Rep 13,117
That frequency sounds about right mine are at 180 for the low pass.
You have to use your ears a little to find the right spot. Or if you want to get real Nerdy about it use one of the eq programs. https://www.channelpronetwork.com/sl...os-and-android Last edited by ctuna; 05-20-2019 at 06:38 PM.. |
05-20-2019, 08:00 PM | #5 |
218
Rep 576
Gotcha, I set them like you said to do. Ive got the amp in and running and it sounds great! Oh how I missed the surround sound effect. Next Ill clean up the wires since they were cut to power my 400/4 and it should be good to go. Thanks for the help once again!
05-21-2019, 05:02 PM | #6 |
218
Rep 576
By the way, what would be a good set of speakers for under $100 to put in the rear shelf? Crutchfield recommended some kicker 2-way speakers but I figured Id ask the e90 guys first before making an order.
05-23-2019, 06:37 AM | #7 |
382
Rep 2,366
Drives: 2007 E90 323i (Cdn)
May be a used set of L7 rears?
05-29-2019, 05:17 PM | #8 |
68
Rep 763
Drives: BMW E90 Dinan stage 3 335I
Man, that unit somehow looks very familiar! Good luck with the tuning buddy nice install job!
2007 E90 335i N54 Montego blue with grey Dakota leather interior
05-29-2019, 05:43 PM | #9 |
218
Rep 576
