BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Fitment issue
      05-18-2019, 11:32 PM   #1
datalpine.e90
Drives: BMW 328i
Fitment issue
So I just started on my second e90 build, a 2008 BMW 335i sedan (stock ride height) and I just need some insight on wheel and tire dimensions and fitment...
do any of you run or know someone or is knowledgeable on if I can run a
Front:
19x9.5
255/30
Rear:
19x10
275/30
~am I able to run this wheel and tire set up or do I need to downsize the fronts to a 245 to be able to make this work?
      05-20-2019, 09:11 AM   #2
DiFFv1
DiFFv1's Avatar
Drives: 335i l 328xi l X5M
Front:
19x9.5
255/30
Rear:
19x10
275/30
Might have to downsize either the rear or the fronts. I suggest removing the ducting in the rear for more clearance. But you are on stock ride height so i see no real problem other than rubbing on dips
"Proud Waitress At Gapplebees"
      05-20-2019, 08:09 PM   #3
Kuokonut
11
Drives: 2007 e90 335i
I run a square 255/35/19 setup, no rubbing issues, stock suspension. 275 is fine in the rear, I've had 30mm spacers in the rear with my 255 setup. i had slight rubbing over bumps with 4 people in the car, but 2 people in the car, no problem. I don't remember my offset, but you should be ok.
