05-17-2019, 08:58 AM | #1 |
130
Rep 1,426
Speaker Distortion
Not sure if this is the right section... I noticed yesterday when in Sport mode my front center speaker has what sounds like static coming through instead of the "exhaust sound" when you press the gas. Also noticed it this morning in comfort mode when I floored it. Has anyone else experienced this?
05-18-2019, 08:29 PM | #2 | |
284
Rep 402
07-17-2019, 01:48 AM | #3 | |
E36, E46, E90, E92, F32
96
Rep 368
When I step on the gas, it sounds like a distorted static sound coming through all of the speakers...as if the engine noise being piped into the cabin is malfunctioning.. Noticed this post was from a few months back. Did you ever figure out the issue?
07-17-2019, 10:03 AM | #4 | |
130
Rep 1,426
07-17-2019, 11:45 AM | #5 | ||
96
Rep 368
Hate these intermittent issues....
ssadri68.50 |
07-18-2019, 10:01 AM | #6 |
47
Rep 82
Yes
M340i w/ H/K, iDrive 7 v03-19. Happened to me this weekend.
First "day road trip" in the car; a couple-hundred mile drive. On the way home, about 20 miles out, just cruise-control 65mph in Comfort, listening to satellite radio. The sound just changed. Didn't hit a bump or do anything. Sounded like the bitrate fell to like 1kbps with lots of digital garbage and buzzing. Almost like alternator buzz or interference. I assumed XM just flipped out, so I immediately lowered the volume. But then noticed I could still hear a buzzing/chirping noise coming from the speakers. It changed pitch and intensity with the accelerator, and got about twice as loud in Sport. Flipped to iTunes playlist, same garbage music quality. Restarted iDrive while driving. No effect - buzzing persisted while iDrive was black-screened. Changed audio sources, they all did it. The system had NO bass at all. Just buzzy, digital-garbage treble. Pulled into a gas station & shut it down. Fake sound stopped when the car was shut off, but the stereo still sounded like garbage. Opened the door, which shut it all off, then got out and locked the door while I ran in and grabbed a bottle of water. Started back up and it was still making the noise. Drove the 20 miles home with the stereo off just listening to the digital mosquitos buzzing around the cabin every time I accelerated. Joy. The next morning, it's perfectly fine. No fake-engine buzzing, stereo sounds great. It hasn't done it again.... |
07-18-2019, 05:09 PM | #8 | |
96
Rep 368
Thanks for the detailed write-up. This sounds like exactly what I experienced...except you did a far better job at explaining it than I did hah. Keep us updated. I'll do the same. Thanks,
Desrste29.50 |
12-23-2019, 10:18 PM | #9 |
115
Rep 219
Drives: '19 G20 330i & '19 G01 X3
Yep.. Just like Delta5 said.. I've had it happen twice to me in my 330i -- the second time this evening.
I rolled video on it so I had evidence of the problem, because for something intermittent, how am I going to get the dealer to acknowledge it? I also have dropouts of CarPlay for 1/2 to 1 seconds fairly regularly -- but I am sure this isn't related. The sound sounded like a ground wire came loose. You could hear it go up and down through revs of the engine as well. I grow more and more frustrated with this car. Last edited by mzdial; 12-23-2019 at 10:25 PM.. |
02-18-2020, 06:36 PM | #10 |
X3M Comp is a beast
89
Rep 171
My M340I just started this tonight. So annoying. I really hope this is not signs this car is going to have problems. So far this is my first problem. And is not good.
09-16-2020, 08:11 PM | #11 |
Rep 17
Seems like the discussion stopped long back on this issue. Hope someone found a fix or reason for this.
I recently got a m340 (one month old) and has the HK system. Noticed the speaker distortion when I accelerate hard. Especially in sport mode. Sound is more like a crackling noise. A few weeks ago I noticed the system randomly lost bass and audio was flat. After I stopped the car, locked and waited for a powercycle. Audio was fine after I started the car. Did not repeat since then. Not sure if anyone got a resolution for this. Wanted to check here before I can take the car in for service advise. |
09-20-2020, 03:04 AM | #12 |
Rep 17
Seeking help if anyone is facing this issue now. Also new update for my previous message.
Today I noticed that the bass intermittently shuts off and audio is briefly flat. Did hear a few distorted noises while this was happening. Switched off Logic7 surround with medium bass setting and equaliser is set to default. This happens when I am not accelerating and just cruising in comfort drive mode. Guessing faulty amp. Just driven 1000 miles and it's already upsetting to see issues. |
09-20-2020, 10:24 PM | #13 | |
51
Rep 126
11-09-2020, 02:21 PM | #14 |
60
Rep 50
Curious if anyone has any updates to this. I love everything about this car except for this one complaint. I fixed the center channel speaker cover rattle soon after getting the car (pretty disappointing for a 60k+ car). That was the most annoying issue. However I still every once in awhile get a loud pop sound through the speakers that sounds like distortion or something. I also noticed a time or two the bass disappear and then reappear. I am thinking its an amplifier issue but would love to know if anyone has resolved the issue and has an answer. I was thinking of upgrading the subs and amp to bavsound units anyways but don't want to waste the money if the issue is in the main headunit and will need to scrap the entire sound system or live with it. It doesn't happen often enough to be too pissed at this point unless it starts increasing in frequency. I will not waste time taking it to the dealer only to leave it for days and get it back with the same issue because they could not duplicate it!
2020 M340i Xdrive Portimao
AA catless downpipe (offroad only of course) BMS intake and Inlet tube H&R Springs MHD Stage 2 E40 |
11-10-2020, 01:07 PM | #15 |
Rep 33
some of the symptoms discussed also here https://g20.bimmerpost.com/forums/sh....php?t=1760766
and here: https://g20.bimmerpost.com/forums/sh....php?t=1724795 I will soon visit friend of mine at dealership who suggested to change the amp. But first he needs to have it checked by technicians to see the error codes etc.
