05-16-2019, 11:19 AM | #1 |
(Sold) '00 M Roadster '06 M Coupe '16 M3 '20 X3MC
1548
Rep 2,588
X3M Weight, some answers
So after doing some quick research on international sites this is what I could confirm:
Jaguar SVR Unlaiden DIN 1995 kg = 4398 lbs Unlaiden EU 2070 kg = 4564 lbs (basically includes 166 lb driver) Jaguar US = 4395 lbs X3M Unlaiden DIN 1970 kg = 4343 lbs Unlaiden EU 2045 kg = 4508 lbs BMW US = 4620 lbs So obviously something doesn't add up, it should be ~4340 lbs (280 lbs lighter than BMW US is reporting). One thing I will note is that the Jaguar SVR comes STANDARD with a panoramic moonroof, while the X3M does NOT. In other countries the X4M does not come standard with a moonroof but it does in the US. Other countries show the X4M weight the same as the X3M. Any guessing to the weight of that moonroof? It can't be 280 lbs, can it? if so then maybe the US based the weight on that being a standard feature... I thought maybe 125-200 lbs max. If it is in fact ~4340 lbs in the US without the moonroof its making me think twice about that option, but I would really want the other things in that package which are not available as stand alone options. BMW really needs to separate the moonroof from that package. |
