05-13-2019, 02:47 PM | #1 |
503
Rep 739
Wheel Fitment
Will these wheels for our cars? I tried searching for the OEM measurements but had no luck. Any help is much appreciated.
Front Wheels: Size: 20 Width: 9.5 Offset: 27 Bolt pattern: 5x112 Hubsize: 67 Rear Wheels: Size: 20 Width: 11.5 Offset: 40 Bolt pattern: 5x112 Hubsize: 67 Thanks!
IG Page: @bo_buttaa
05-13-2019, 04:54 PM | #2 | |
19361
Rep 10,166
OEM is 20x9.5 et28 20x10.5 et28 Your proposed fronts will fit The rears should fit too but Id check in the inner lining for rubbing. The 11.5 inch wheel is about 12mm more to the outer than the OEM 10.5 but with a wash on the offset since its bumped back to 40. Bolt patterns are the same and our CB's are 66.5
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
05-14-2019, 02:40 PM | #3 | |
503
Rep 739
As for the CB/HubSize, I see there is a discrepancy as well. The wheels spec indicate 67mm but you are saying our CB is 66.5. Is this a rounding differential or a real difference?
IG Page: @bo_buttaa
05-14-2019, 03:36 PM | #4 |
19361
Rep 10,166
thats a tough question, I believe the .5 mm is ok but we might need a tire/wheel expert to chime in.
