2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions M Button Retrofit
      05-12-2019, 08:41 PM   #1
EVEda235i
Mr. Clutch
EVEda235i's Avatar
Drives: 2015 M235i
2011 BMW 335i  [9.50]
M Button Retrofit
Hi guys. I've looked far and wide, but it seems no one has attempted this. I was looking to see how feasible it is to buy the M1 and M2 buttons and install them where the blanks currently sit. Pics of buttons below
Obviously you would need the M-Sport wheel WITHOUT the active cruise control. Reason i ask is if i can get the button cover to physically press like the rest than I could theoretically put a button behind it (think keyboard) and wire that to a remote that controls an aftermarket exhaust valve or meth kit.
If u have ideas or have seen someone already attemot this please share.
Cheers
Quiet M235i
      05-13-2019, 10:42 PM   #2
bmtespar
bmtespar's Avatar
Drives: 19 X3 30i, 18 230iX Vert
Neat idea but unless you tap into the hub centric ring, you'll run into problems with the wires tangling when you turn the wheel.
Another idea would be to install momentary switches on your shift paddles. I'm sure you could get a really thin switch and route the wiring behind the paddles. Just another idea.
Current: 20 M340i
Sold: 19 x3 30i X drive, 18 230i X drive Convertible
18 x3, 30i X drive 16 428i Convertible, 16 X1 X drive, 14 i3 Rex, 14 328i, 14 x1 28i X drive, 08 328i, 03 M5, 99 323i Convertible, 00 z3 M Roadster, 99 328i, 00 323i
      05-13-2019, 10:59 PM   #3
EVEda235i
Mr. Clutch
EVEda235i's Avatar
Drives: 2015 M235i
Appreciate the heads up. Will definitely require some tinkering.
Planning on running cables through as close as possible to the center of the wheel. Hopefully any pulling can be prevented with plenty of slack.
Paddle idea is cool too but I've got a 6mt
Quiet M235i
2addicts
