Non working comfort access e93
05-12-2019, 03:06 PM | #1 |
Rep 15
It’s been awhile since my comfort access stopped working. Just randomly stopped working and it’s been like that ever since. Here’s the breakdown:
Key fob, door handles nor keyless start does not work. So far I have done: replaced battery, replaced key fob battery, manually checked all fuses (don’t have diagram). My dealership is a complete rip off, $200 just for diagnostics. I only have 1 key fob. One time my key worked at the bottom of my drivers side rear bumper, weird as hell right? I can only start my car with the key fob inserted and use the actual key to open the doors. No engine or trouble codes on dash. I’ve looked through the forums and tried other solutions but no avail. Any suggestions would be amazing! |
05-12-2019, 04:12 PM | #2 | |
2714
Rep 4,042
However, if it suddenly quit working one day and then NADA, except perhaps once working at the rear bumper antenna (actually NOT weird as there is an antenna there) and changing the battery in your remote did NOT help, then that suggests a system problem in the car that prevents the system from detecting the signal produced by your remote key, rather than a problem with the key radio signal. Obviously the key chip works fine as you can insert key in slot and start car. A Dealer should have the ability to test for signal sent by CA remote key. Did they NOT do that, and/or NOT explain to you the result of that test? Do you have any written receipt or invoice stating what tests were performed and the results, Fault Codes, etc.? Any Electronic Module has INPUTS (antenna signals in this instance) and OUTPUTS (here to unlock, activate ignition, etc.) and INPA/ISTA can tell you if (1) the module is responding to connection via the OBD II Socket, (2) read "Inputs" such as any signal received from the remote key, and (3) Activate the system by producing "Outputs" to unlock or activate the ignition. That is the easiest way to test the functionality of the system and get clues on what is NOT working as intended, as well as to read Fault Codes or Freeze Frame Data saved in Module Memory. You might get lucky and be able to test the system yourself simply using the circuit diagrams & a multimeter. For instance, here is the TIS circuit diagram for the CA Control Unit, "A215" in this link: https://www.newtis.info/tisv2/a/en/e...ess/1VnXU4jrfZ Start by checking fuse F61 (5A) which is the top fuse in the 2nd column from the left, F57 being at the bottom of that column as shown in this TIS "Installation Location": https://www.newtis.info/tisv2/a/en/e...cab/1VnYo8ECDO There should have been a "trifold" attached to the removable panel of your glovebox, but I'll attach two pages from Bentley that show 2008+ fuses to the next post (so as NOT to mess up margins in this post). Here are other TIS resources if you decide to tackle it yourself: Convenient Access System Inputs: https://www.newtis.info/tisv2/a/en/e...access/unjV9QB Comfort Access Functional Description: https://www.newtis.info/tisv2/a/en/e...access/XPJiwrn Installation Location of Comfort Access Control Module (A215): https://www.newtis.info/tisv2/a/en/e...i-cab/HOtUza7g Installation Location of Aerial Diversity, A421: https://www.newtis.info/tisv2/a/en/e93-335i-cab/RaC3fJu Please let us know what you find, George |
Persian Whisperjet166.50 |
05-12-2019, 04:15 PM | #3 |
2714
Rep 4,042
Bentley Fuse Chart, two pdf pages, for 2008+ (2008 & later) E9x:
05-12-2019, 05:48 PM | #4 | |
Rep 26
05-12-2019, 11:38 PM | #5 |
29
Rep 88
I am also dealing with the exact same problem.
https://www.e90post.com/forums/showthread.php?t=1611109 I did found a blown fuse rated 20a. I replaced it with 15A because that all I have. Looking at the chart you provided. I can't find the 20A slot. [IMG][/IMG] I just finally have time used INPA to scan. But I have no idea what it means. Here are the results: CID A468 E5C4 FRM 9CC3 KOMBI A3B2 9319 931A FZD A668 9319 931A Any idea what does that mean? |
05-13-2019, 04:30 PM | #6 | |
2714
Rep 4,042
https://www.newtis.info/tisv2/a/en/e...9-fuse/om5ZfPe F19 Installation Location, TIS: 4th from L in row beginning F16 https://www.newtis.info/tisv2/a/en/e...use/1VnYLtbcQt I presume those codes are from using "Functional Jobs" in INPA, and copying the code numbers. There's a way to use INPA to connect to each MODULE that has a Fault Code, and get the Code Definition, Freeze Frame Data and other code details. You can also use "Print Screen" (Shft+PrtSc) to copy the screen, paste it to Paint, and SaveAs a jpg file in a folder chosen/ created by you, for future reference and attachment to posts on a forum for help. If you need help doing any of those things, just let me know & I'll provide steps. George |
05-13-2019, 04:36 PM | #7 |
2714
Rep 4,042
F19, Models Built BEFORE 3/1/2007
RL325xi (2006 E91) Fuse F19 (7.5A) Fuse location, RED Rectangle
Fuse for CA module & Door Handle modules BEFORE 3/1/2007: |
05-13-2019, 06:40 PM | #8 | |
2714
Rep 4,042
0) Open Paint (Windows 10 accessory Photo Editor) or Editor of choice; 1) Select "Functional Jobs" in the Right ListBox at the screen after selecting E90; press Enter; Menu should appear; 2) At the Functional Jobs Menu, select F2, Identification; that screen should list ALL ~ 20 modules in your vehicle; 3) After the "Identification" screen has appeared, press Shft+PrtSc to save that screen as an image file in working memory; 4) Alt+Tab to navigate to Paint; Paste (Ctrl+V) the screen to Paint & SaveAs a jpg file in folder of your choice for future reference and attachment to post here. 5) Do the same for Functional Jobs > F4, Fault Memory (Fehlerspeicher), which lists Fault Codes saved in ALL Modules: PrintScreen, copy to Paint, SaveAs jpg file, and attach it here along with F2, Identification. We can then walk you through how to connect to each module which has a fault code, and get MORE information on that code than Functional Jobs gives. MAKE SURE: you provide your current mileage, and estimate of mileage when CA issue began, as perhaps the MOST important Freeze Frame Data point is the mileage/km at which the Fault Code was saved in module memory. Examine the Functional Jobs > F2, Identification screen carefully and note that the modules are listed in numerical order of their ADR -- the first column; each module has an abbreviated name like DME for Digital Motor Electronics (or German translation); FOURTH column is key: SGBD is the "CodeName" for the module, and it includes the "variant" of that module, such as "87" following JBBF (Junction Box Electronic Module). The same code number may have a different "Definition" in different modules, so ALWAYS make sure you know your full Module CodeName (SGBD). The codes you posted do NOT have anything to do directly with a CA fault/issue. Possible exception: K-CAN wire fault (CID/E5C4). General description (which may change slightly depending upon module variant as described above) (1) possible driver's outside mirror communication issue; (2) Communication issue between KOMBI & CAS; (3) Fuel Gauge in KOMBI may not be reading correctly due to Fuel Level Sender (L&R) issues; (4) Right-front reading light issue? Remember, these may be old codes where the fault is NOT currently present, so we need to see the Freeze Frame Data & Details. When you supply the ScreenPrints of Functional Jobs F2 & F4, please also indicate what performance faults, symptoms or issues you have (such as Fuel gauge or reading light) and if there was any problem with F19 (test it visually AND electrically with multimeter). INPA is a powerful tool, but it takes time to get familiar with it. If you are going to be able to diagnose your own vehicle & save $$$$, it's WORTH it, so hang in there. George |
05-14-2019, 10:10 PM | #9 | |
29
Rep 88
Thank you george for the instruction. will perform another scan from INPA as per your instruction and get back to you. By the way the 7.5A is good. that was the first one I check. What do you think of my blown 20A for? |
05-15-2019, 12:15 AM | #10 |
1915
Rep 13,107
Did you find the fuse map on the back of the glove box cover
it kind of tells you what the fuses are. You didn't list the fuse number. Fuse board looks different than the one in the Bently manual. If it doesn't there is always the first two links of georges links https://www.bimmerfest.com/forums/at...9&d=1539905743 Last edited by ctuna; 05-15-2019 at 12:46 AM.. |
05-15-2019, 08:12 AM | #11 | |
101
Rep 474
05-15-2019, 10:44 AM | #12 |
Rep 15
George thank you for all the info. I tried to follow everything as the best as I could. I do have all the bmw software, I ran ista and inpa as requested. I also checked all the fuses mentioned and a few more but unfortunately they were all intact. I've never had a fuse map for my car so I've always relied on online diagrams. I checked my battery to see if I missed any connections but it was all correct. I don't really know where the diversity antenna is located. I'm thinking its either that or the CA module. Ista/inpa pics attached. Thank you
05-15-2019, 11:29 AM | #13 |
1915
Rep 13,107
Inpa is saying it's not reading most of your sub modules
and Inpa is not reading them as present. Are there any errors from the CAS in Ista and from the other modules that aren't being read . Do you have a tune that is turned on? I wonder if the e93 has a different fuse board than the others as it has to support circuits for a retractable roof although I did not see any variations in the Bently Manual. |
05-15-2019, 04:27 PM | #14 | |
Rep 15
05-15-2019, 08:46 PM | #15 | |
2714
Rep 4,042
Installation Location of Comfort Access Control Module (A215): https://www.newtis.info/tisv2/a/en/e...i-cab/HOtUza7g Installation Location of Aerial Diversity Module, A421: https://www.newtis.info/tisv2/a/en/e93-335i-cab/RaC3fJu 2) ISTA: I have never used ISTA so can't give suggestion as to next steps on that, or whether it appears to be working properly. 3) INPA: as ctuna suggests, you have ~ 20 modules in your 2009 335i E93, but only THREE (3) are showing on the screen you copied from Functional Jobs > F2, Identification. There is either something wrong with your INPA installation on your cable setup. Have you set USB Serial Port Settings to COM1 & Latency 1? If not post back, indicate the cable brand (e.g. BimmerGeeks) & ask for help. Also, make sure the slide switch on the cable is in the "Far-Right" position a~ 20 s viewed with pins pointing to 12 o'clock and brand label facing you (if BimmerGeeks). Another trick to try to get MORE of the modules to show up in F2, Identification is to continue to press F2 every few seconds to essentially "reload" that screen, until more/all modules appear. Since I don't have CA, I'm NOT sure if there is a separate Module for that or NOT. Perhaps someone with both CA & INPA can answer that question and indicate what ADR number it has, so you know where to look for Faults saved. It may all be in CAS, but if there is a separate Module for Comfort Access, then you should check that as well. So if you want to try to get INPA to work, I'm able to help there, otherwise someone else will have to help on ISTA. Just to get started in INPA, you need to connect to "Functional Jobs" which you appear to ALREADY know how to do since you attached the F2, Identification screen, and you know how to save a screen and attach it to your post here, so we're getting close. Suggested next steps for INPA diagnosis: 1) Connect your Cable to the USB port of your laptop (NOT the OBD II Socket of vehicle, JUST computer); 2) Open Control Panel, Select Device Manager, Ports (COM & LPT); 3) Double-click USB Serial Port & select Port Settings Tab; 4) Click "Advanced" box & set (a) Com Port# = COM1 & (b) Latency Timer (msec) = 1; Close Control Panel 5) Connect cable to OBD II Socket & with Ignition on, engine OFF, in INPA, Select Functional Jobs > F2, Identification, and see how many modules show up; if NOT ~ 20 different lines with module ADR in first column and Module Name in 2nd column (like your screen you posted, just MORE lines/ modules), press F2 about every 5 seconds 3 or 4 times and see if you get more. Press Shft+PrtSc each time you get more than 3, and save/post that screen when you get ~ 20. 6) Select Functional Jobs > F4, Fault Memory, All Modules, PrintScreen, SaveAs jpg file & post here. THEN we can help with next steps which will basically involve connecting to CAS or other modules with fault(s) related to CA, and see what clues are hidden in Fault Memory. George |
05-16-2019, 12:35 PM | #17 |
44
Rep 236
Carly Coding - Deactivate Comfort Access
I'm sure this is not your issue, but I recently had the CA is my new to me 335i stop working entirely. The original owner indicated that CA has always been intermittent (I think he had door handles replaced).
Right from the get go the car had been showing the battery icon on the car. It was a second vehicle and not driven much by the original owner, and the battery in the car was original. I could see that the CA behaved most of the time if the car was driven and charged up. Other times when it was sitting, it would not work. This week I put a new OEM AGM battery into the car, and still no CA. Neither of the keys would work, and neither door handle worked, which was strange from my previous usage over the few weeks I've had the car. Last weekend I borrowed a friend's Carly adapter and coded in some basic things like windows close with FOB, door lock, and CA buttons. I went back and looked at the settings yesterday and I recalled seeing the option "DEACTIVATE COMFORT ACCESS" in the list and the default setting was OFF. In the process of coding the window control, I believe I saw this and changed it to ON (since the setting is called DEACTIVATE CA, I presumed ON = deactivated, and OFF = active). I changed the setting back to ON and the CA started working perfectly again. I emailed this to Carly last night in hopes they might update the settings to be more clear. But if you've done any coding with Carly, just make sure you didn't change this setting to OFF. |
05-16-2019, 12:47 PM | #18 |
11503
Rep 1,067
Just throwing this out there, as it happened to me on my E93. Do you have aftermarket puddle lights? After I installed some cheap ones, my CA went haywire. Swapped the OEM led puddle lights in and everything was back to normal. Interference from the non shielded Chinese junk I guess.
E46, E60 M5, E93 M3, F15 X5
IG - @thebimmerhaus |
05-17-2019, 05:07 PM | #19 | ||
Rep 15
05-17-2019, 05:09 PM | #20 | |
Rep 15
05-17-2019, 05:27 PM | #21 | ||
11503
Rep 1,067
05-19-2019, 01:23 PM | #22 | |
2714
Rep 4,042
So the good news is you appear to have a fully-functional INPA, which can diagnose issues as well or better than most anything else, AS LONG AS YOU KNOW HOW TO USE IT. I do NOT know anything about Comfort Access except what I see in TIS & Bentley. What I would need to see is the 2nd & 3rd screen of Functional Jobs Fault Codes in ALL Modules. The screen you posted two days ago ONLY shows faults in #12 DME, and the Last Module shown is #29 DSC. We need to know what other modules AFTER DSC have Faults, particularly #40 CAS, but ANY others > #29 DSC. ANYONE know if the CA Module has its own Fault Memory, and if so, what Module it is in the 2nd list of all 27 Modules in the vehicle? If you will just post Functional Jobs F4 > F1, screens AFTER #29 DSC, we can hopefully make some progress quickly on this. If you want to try your hand at connecting to the CAS Module while you're getting those Functional Jobs screens, here is how to do it (and read Fault Codes & FF Data saved in CAS Memory): 1) Open Paint so you can copy screens from INPA to SaveAs jpg files; 2) Select E90-E93 and in Script Selection Box, Tab down to Body/Karosserie in Left ListBox; 3) Tab to Right Listbox, scroll down to "Car Access System" and select; 4) CAS Main Menu appears; select F4, Fault Memory, and then F1, Read Fault Memory; 5) Save ALL Fault Memory Screens and post here. George |
