05-11-2019, 09:42 AM | #1 |
727
Rep 649
Musicar NW trunk sub installed
Finally got my amp and sub installed. The amp is installed under the rear deck and is powering the trunk sub and it's also set up to powered the underseat subs. The amp is set up to filter out the low bass frequecies so that the underseat woofers are handling mostly mid-bass duties.
CURRENT///G80 M3CX | Isle Of Man Green | Kyalami Orange | Bi-Color 826M Wheels
FORMER ///F80 M3 ZCP | Yas Marina Blue | Black | DCT | Black 666M Wheels FORMER ///F87 M2C | Alpine White/Orange | DCT | Black 788M Wheels FORMER ///F87 M2C | Sunset Orange/Orange | 6MT | Black 788M Wheels FORMER ///F82 M4 | SSII | Full SO | 6MT | Black 437M Wheels |
05-11-2019, 02:22 PM | #3 |
727
Rep 649
The amp is a JL XD 1000/5v2 and the sub is an Audiofrog GS 10 series sub.
05-12-2019, 09:32 AM | #4 |
197
Rep 258
05-12-2019, 09:37 AM | #5 |
727
Rep 649
Not at this point. I'll give the system some time. At this point I probably don't yet have 12 hours on the speakers. I'll continue to fiddle with things before I make any more modifications.
05-14-2019, 09:44 AM | #6 |
504
Rep 780
05-14-2019, 09:49 AM | #7 |
727
Rep 649
It sounds better but still not as awesome as the same setup in my old M4 sounded. The bottom end is there now which is a huge improvement. I'm still working on perfecting the blend between the trunk sub, the underseat woofers, and the door speakers. It's tricky. The starting point in this car is quite bad, so getting it dialed in is proving trickier than I thought.
05-15-2019, 07:14 AM | #8 | |
504
Rep 780
I added the Match UP - 7BMW amp and all new speakers ( JL audio and SWS under seats. Pretty amazing sound. Could do better on the sub base but still way, way, way better than stock.
"I would rather cry in a BMW than smile on a bicycle." Ma Nuo |
08-28-2020, 10:36 AM | #10 |
727
Rep 649
I mounted it to a piece of 1/2" thick plastic which I then mounted under the rear deck in the trunk. It worked well and kept it out of the way and largley out of sight.
Pottah203.00 |
08-28-2020, 03:23 PM | #11 |
203
Rep 166
biggripper726.50 |
09-29-2020, 12:37 PM | #12 |
203
Rep 166
Do you have a close up pic of your amp and how you mounted it? I'm getting my Visual Ice box soon and I'm looking to do something similar. Thanks!
09-29-2020, 06:36 PM | #13 | |
727
Rep 649
Pottah203.00 |
09-30-2020, 08:43 AM | #15 | |
203
Rep 166
Yeah, I was thinking of that too as I have a somewhat small Amp - Alpine MRV-M500 |
09-30-2020, 12:40 PM | #16 |
5943
Rep 3,292
There's about an inch and a half of clearance for the JL 300/1. Check the height of the Alpine and consider what material you want to use between the amp and the metal floor. I had a friend 3D print small form-factor mounts with high temp material.
10-06-2020, 12:34 AM | #20 |
320
Rep 295
01-08-2021, 02:36 AM | #22 |
184
Rep 923
Drives: LCI M2
Hey OP. May i ask where you grounded the amp in the trunk? Did you make a new hole somewhere or you used a current one? If so, which one did you use?
