05-10-2019, 11:47 AM | #1 |
20
Rep 109
Possible to separate actual trim piece from the part itself?
Hello friends! I will be carbon fiber skinning my interior trim and I was wondering for the main center dash trim if the wood can be removed from the metal portion? The gap is really small in between those two pieces so I don't want to risk getting epoxy on that metal part? Has anyone done carbon fiber skinning themselves? UKF30 has done it before but I he hasn't responded to my messages. Please let me know
05-10-2019, 03:39 PM | #2 |
8245
Rep 16,089
Yes. You'll see on the back of the assembly plastic rivets that hold the two pieces together. Remove the mushroomed part with a 1/4" or so bit in an electric drill and you can separate the parts. After wrapping the wood part reassemble them, using a hot melt glue gun to replace the rivet mushrooms with hot melt glue. I don't know where epoxy enters into the equation. My preference for carbon fiber wrap is 3M Di-Noc.
05-10-2019, 09:59 PM | #3 | |
20
Rep 109
