05-09-2019, 12:44 PM | #1 |
25
Rep 61
Drives: 2016 F80 ZCP, 1992 R32 GTR
H&R springs... M5 or M550i?
Hey, placing an order for a set of H&R springs soon. I was originally going to order the M5 ones but some people are telling me the M550i ones are better. I'm on the stock rims but not doing spacers. I would do spacers later on if really needed(I'm also looking into building a custom oil guard based off the IND one)
Give me a follow on IG @rcs.tyson
05-09-2019, 12:54 PM | #2 |
25
Rep 61
Also will I be needing an alignment afterwards?
05-09-2019, 01:16 PM | #3 |
194
Rep 459
H&R 550 has the lowest drop and best look
2019 F90 M5 Comp-Marina Bay Blue-B&W,HRE 21" FF04,BMC,CarbonPro wing,H&R,ZW5
2017 BMW 330i - Estoril Blue - M Sport Package 2013 Lamborghini Aventador-Pearl Green-Modified 2004 Lamborghini Gallardo-Manual 6spd -Giallo Midas Pearl Yellow-Modified 2018 Range Rover Velar S-White |
05-09-2019, 01:34 PM | #4 |
4074
Rep 5,233
M550 H&R looks better if you like a more aggressive look; if looking for a more conservative drop go M5 H&R.
I personally like the 550 H&R's more. I always do an alignment when I do suspension; I would wait a couple of weeks for the springs to settle before aligning. I went with KW HAS.
05-09-2019, 03:42 PM | #5 |
188
Rep 1,548
The KW HAS kit allows you to achieve the perfect drop for you. Everyone has their own preference.
CURRENT:
His: Porsche 991 Turbo S Carrera white/Black Hers: BMW X3MC BSM/Black |
05-09-2019, 08:25 PM | #6 |
///M
6654
Rep 3,683
Agree, I would definitely go with KW
Life is too short...enjoy your life
///M |
05-09-2019, 09:03 PM | #7 |
12966
Rep 18,713
If you know that you will like the drop with M550iX spring, then go for it.
But, if you are not sure, invest in KW HAS. At least you won't need to buy a new set of spring and pay another installation labor. Especially where you are at where labor are expensive.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
05-09-2019, 09:55 PM | #9 |
1110
Rep 1,314
I have M550 springs. Very happy.
Instagram-Pazzo009
F90 M5(gone), S580 (until G90) X5M, 812SF E46 M3 (LSB on LSB) E36 M3 Avus |
05-09-2019, 10:10 PM | #11 |
2337
Rep 2,029
Drives: INDIVIDUAL F90 M5C LCI
How is the ride quality on the M550i springs? And correct me if I'm wrong- but doesn't the KW HAS kit allow for some minor adjustability to go as low?
CURRENT: '21 M5| FSHNGRY | TARTUFO | CCB | MPE | KW | IND | EVENTURI | EISENMANN | DINAN | LOADED |
GONE: '15 F82 M4 | YMB | IND | MPERF | KW | BM3 | LOADED GONE: '11 E92 335IS | BLKSPHR | OYSTER | LOADED GONE: '05 E46 ZHP | LOADED | DINAN STG3 PKG | IG: @FSHNGRY |
05-10-2019, 07:51 AM | #12 | |
1110
Rep 1,314
My car rides amazing. In fact, it has less bounce than it did with the stock springs. I am very happy and always have had good luck with H&R in general. I'm also running 10mm spacers on all 4. No issues, no rubbing...
Instagram-Pazzo009
05-10-2019, 09:27 AM | #13 |
19355
Rep 10,166
I would have gone the M550 way but when I lowered my car back in August with the F90 M5 H&R's I dont think anyone was doing it and I was not going to be the crash test dummy. So I have the M5 ones and the drop is much more moderate yet while I want to swap I keep looking at my car and realizing... Im just fine. The ride is practically unchanged with the limited changed in compression and rebound.
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black Last edited by Vic55; 05-10-2019 at 09:43 AM.. |
05-10-2019, 01:25 PM | #15 | |
19355
Rep 10,166
You cant go wrong with either so its purely a subjective approach. If I had more intel personally on the M550 set up I would have done that but again I lowered my car on one of the first sets of F90 springs back in August. And to be honest, H&R did not post their drop levels correctly because I was under the assumption they would drop 1.2 square it didnt:
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
05-10-2019, 10:55 PM | #16 | |
2337
Rep 2,029
My question was- Does the KW HAS kit allow you to go as low as the M550i springs? I couldn't imagine the car looking good or riding with any sort of practicality if it were any lower, aside from it not being my style to begin with. OEM+ FTW
05-10-2019, 11:26 PM | #17 | |
1110
Rep 1,314
Also, and I could be mistaken, but do you lose dampening adjustments with the KW?
Instagram-Pazzo009
05-11-2019, 01:18 AM | #18 |
420
Rep 862
Retired 2016 BMW 550i xDrive MSport | 2013 BMW 550i xDrive MSport | 2012 BMW 535i xDrive | 1988 BMW 325ic | 1984 BMW 318i
05-11-2019, 11:37 AM | #19 | |
19355
Rep 10,166
Ive run about 13 sets of KW's in my life and while I told myself I could adjust the height and justified my purchases at times that way; I think I only adjust one car after the initial drop. I think 550 or the F90 is the way to go based on your preferences.
05-14-2019, 02:03 PM | #20 | |
500
Rep 1,313
E92 M3 Supplemental manual p.38: "The laws of physics cannot be repealed, even with DSC."
05-14-2019, 04:11 PM | #21 |
19355
Rep 10,166
If you are more on the conservative side this is your way to go; I am not so much but like I had said it was done back in the day with no real intel on the M550i stuff.
05-16-2019, 06:14 PM | #22 |
500
Rep 1,313
Well, I really like the look of your car's stance. So much so that I ordered the same springs and spacers from Ben today!
r33_RGSport12966.00 |
