08-04-2008, 11:31 PM | #1 |
BMW Novice
69
Rep 237
Drives: M Coupe
Bluetooth problem
Does anyone has an idea why when I try to synchronise my phone through Bluetooth, it doesn't want to go past the "phonebook loading" part??? Most often it just disconnects my phone, and one time I was waited like 15 minutes for it to load but nothing happened.
I can dial number through the mic, but I want to be able to answer calls and stuff. Thanks guys
04-08-2011, 10:24 PM | #2 |
11
Rep 37
I know this is a very old thread - but there were no responses and I'm having the exact same problem. My phone pairs and I can make hands-free calls; I can even use the voice control system. But my phonebook refuses to load and simply flashes "PHONEBOOK LOADING" without ever loading the phonebook. When I ask it to "read the phonebook" it responds that the phonebook is empty.
Does anyone have any ideas as to what the problem is? Am I doing something wrong? This is not covered in the telephone manual I received with my manual package. I have a 2007 Z4 3.0Si. My phone is a Samsung Epic 4G Android and, as I said, it paired easily and works fine. Thanks in advance for any assistance you can offer. (BTW - at least you know I used the SEARCH function first - or I'd have never found this thread!)
Kerry
04-08-2011, 11:13 PM | #3 |
Rep 167
I paired up my phone and everything worked as expected out of the box. The only thing I did was make sure to update the Nav software to the last version (v32), before I did anything else.
Shamelessly copy pasted from Ron Stygar's post: Part# 01 59 0 141 891, retail $8.90. |
09-14-2011, 11:45 PM | #7 |
Rep 39
Hi guys - since you paired your phone successfully, maybe you can help me: I purchased my 2006 Z4 3.0si Roadster from a used car dealer and it didn't come with a radio manual and I am having difficulties pairing the iphone 4. I am not even 100% sure the car has functioning blue tooth: The phone finds the car but when I punch in a pin-code that I believe I am supposed to come up with myself, it doesn't offer to punch it into the radio as well, it just doesn't accept the pin-code, period. I assume my car is equipped with bluetooth since I have the little mic for the hands-free caling on my steering column. Can you help?
Philipp |
09-15-2011, 11:22 AM | #8 |
181
Rep 623
Voice dialing does not use your phone book, it is seperate and you must set each voice user up with the commands. Kind-a sucks, but at the same time it needs to learn how you talk.
Steve |
09-15-2011, 11:25 AM | #9 | |
24
Rep 784
Drives: 2011.5 E90 M3
09-16-2011, 08:31 PM | #10 |
190
Rep 2,431
That's correct, only I have no use for bluetooth in my car since my exhaust
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm Gone:z4m, boss 302, c6 z06, m6,z3m |
