05-03-2019, 10:31 PM | #1 |
550
Rep 949
B58 E85 JB4+MHD Dyno
With the official release of MHD for the B58 today seemed a good time to share some dyno results to highlight one of the problem areas with the platform.
Test car is Jeff @ BMS 540i with a BMS intake, JB4, and MHD back end flash map. The flash map has been adjusted to accept from 20-50% E85, with fuel trims, lambda target, and timing advance, optimized to the expected power levels. They are running on an E40 mix here and at only 19psi fuel pressure is already tanking, and that is with AFR as lean as they feel safe running it! While flash tuning has removed the software fuel cap we've still got some hardware fuel limitations to deal with. Option 1 is the tried and true meth kit, and option 2 is a new CPI (chargepipe) injection setup we're working on. Expect to see more on that soon we're testing it on our Pure Stage2 B58 right now. |
05-04-2019, 10:48 AM | #5 |
550
Rep 949
05-04-2019, 10:52 AM | #6 | |
810
Rep 1,454
As a customer, I'm willing to pay $$$ for a plug and play situation. We're not the cheapo 10-year old N54 crowd lol. Sorry for all the questions, just trying to learn more
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2 |
j1980mac262.50 |
05-04-2019, 11:04 AM | #7 |
550
Rep 949
Yes you need an electric controller or a JB4 for the CPI, we have options for both. I know other companies are working on high pressure pump upgrades so you also have those options. From what I've seen they start in the $2500 range. CPI is something you could do under $1000 including the kit, controller, chargepipe or adapter plate, and even throwing in a flex fuel sensor for good measure.
The B58 aftermarket is just starting to open up so you'll have no shortage of options I'm sure. |
G.Newt810.00 |
05-05-2019, 10:40 AM | #9 |
550
Rep 949
05-05-2019, 11:03 AM | #10 |
558
Rep 1,457
Is your source of fueling going to be like meth injection practically through a throttle plate?
2024 X3 M40i
2014 BMW M5 |
05-05-2019, 11:17 AM | #11 |
550
Rep 949
05-08-2019, 11:01 AM | #12 |
Cheapskate
4450
Rep 4,993
So if you were able to run 19psi on a PS2 turbo, what's the limitation on stock turbo? I think a stock turbo E85 tune would be awesome and we've seen some dynos from other tuners the past few weeks.
05-08-2019, 11:36 PM | #15 |
BimmerPost Supporting Vendor
24199
Rep 190,807
05-09-2019, 01:39 PM | #16 |
558
Rep 1,457
I truly think this is possible 🤙🏻
2024 X3 M40i
2014 BMW M5 |
09-02-2019, 03:09 PM | #19 |
560
Rep 1,503
Were EWG wires being used in this bef setup?
FBO M235i r
F80 M3 |
09-03-2019, 03:53 PM | #20 |
187
Rep 458
Any updates from Fuel-It! Wondering if their CPI kit is good enough for full E85 on a stock turbo or PS2.
