Steering wheel spun when rack was removed
04-28-2019, 10:53 PM | #1 |
433
Rep 780
So while the steering column was disconnected from the rack the wheel was spun. How can I fix it? My thought was to turn on the headlights and aim them straight.
Other thoughts? |
04-28-2019, 11:33 PM | #2 |
463
Rep 2,768
you should remove steering wheel, switch centre and check slip ring cassette
if you did not more than 2.5 rotation in any direction everything will be good if more - then slip ring will be damaged
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
Vulcan50432.50 |
04-29-2019, 02:27 AM | #6 |
463
Rep 2,768
if you do not want to remove steering wheel, then when you assemble everything and try to drive, if you have multifunctio buttons not working and airbag fault is lit on instrument panel, then slip ring is damaged
Vulcan50432.50 |
05-02-2019, 11:06 AM | #8 |
433
Rep 780
Update
I turned on the car and checked the steering wheel controls, those work fine. So then I confirmed corner light function to center the steering wheel. Centered the rack, and put it back together!
