04-26-2019, 09:32 AM | #1 |
Rep 65
VRSF Vs CTS Turbo Catless Downpipe
I saw that CTS Turbo has a similar offering for about $30. Does anyone have experience with either that would sway them in one direction?
I've read about fitment issues on VRSF so is $30 more for CTS worth it? |
04-27-2019, 04:02 PM | #4 |
102
Rep 128
04-28-2019, 11:08 AM | #6 |
102
Rep 128
Mine had no fitment issues.
It was the fact that there is no mounting bracket where OEM cat mounts directly to the car, and where all other aftermarket manufacturers have this OEM mounting bracket, that taught me why VRSF are cheap. All the weight is now directly imparted on the connection point between the turbo and the DP. Good luck with that. My exhaust guy has fabricated a clamp and bracket system. It should have come like that from VRSF's factory. There's a reason why the other 5 or 6 aftermarket brands have that bracket. |
04-28-2019, 11:17 AM | #7 |
404
Rep 808
CTS turbo makes a quality product. Big fan of my downpipe from them
04-28-2019, 03:17 PM | #8 | |
558
Rep 1,457
nzuberi29.00 |
04-28-2019, 04:53 PM | #9 | |
102
Rep 128
N55 downpipes are minuscule compared to the size and weight of the B58 downpipe. To think that it doesn't need the mounting bracket, whereas OEM and all other manufacturers make use of the mounting bracket - that's simply lazy ass engineering. Not to mention the salesperson never explained why they didn't think the mounting bracket was required, after many repeated questions from me as to "why?" Simply ignorant engineering. |
alohasurftoad3081.50 Mikej0h48.50 |
05-01-2019, 02:08 AM | #10 |
BimmerPost Supporting Vendor
24199
Rep 190,807
VRSF fits without any issues and we offer lifetime warranty with all their products
B58557.50 |
05-02-2019, 06:04 AM | #11 |
Cheapskate
4450
Rep 4,993
I like CTS Turbo. I have their big turbo kit on my volkswagen and Clay helped me out a lot in the past. However I don't see a B58 Downpipe offering on their website yet. They also said that they're working on a garret turbo hybrid kit to upgrade our stock turbos, so I'm waiting on that too.
The VRSF pricepoint is right but I'm not a fan of the hit or miss feedback I see. And if it fits but no bracket means excessive vibration, potentially breaking welds, etc. then I'll wait for something else that's reasonably priced. Edit: Nevermind, I found it. For some reason they only have it linked to the G30? Also looks like it doesn't use a bracket either. https://www.ctsturbo.com/product/cts...e-for-bmw-b58/ |
bm3tuning70.00 alohasurftoad3081.50 |
05-02-2019, 08:37 AM | #12 | ||
70
Rep 93
2 of my 340 friends have their DP, just search B58 and it should come up We have CTS Turbo DP installed across all our friends in the area (N55 / S55 / B58) Some guys with M3/M4 have recently gotten their Intakes as it doesn't cause any MAF issues like others. I remember in the N55 so many folks having MAF issues with Intakes except CTS came out to be 1 of the 3 that didn't. Speak Highly! |
05-02-2019, 10:43 AM | #13 |
24199
Rep 190,807
Your best option is the Evolution Racewerks downpipe
05-03-2019, 05:38 PM | #14 | |
IG @bmwF9xG80
3813
Rep 7,593
Friend just sent me a pic of his CTS B58 DP for his X3 M40i and other friend getting his next week for 340
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 Last edited by FSociety; 05-03-2019 at 07:36 PM.. |
the dope steez404.00 |
05-12-2019, 07:04 AM | #15 |
Uhh... Khakis?
54
Rep 155
Hey Mike, why do you feel the ER catless is the best option? Is it the ceramic coating? Seems like all of the options are similar in design and just curious what would justify the additional $$ for the ER. I am seriously asking because I have the CTS Turbo DP and I’ve not had any issues.
Just wondering if I’m overlooking something. Thx! |
05-12-2019, 12:35 PM | #16 | |
558
Rep 1,457
2024 X3 M40i
2014 BMW M5 |
05-13-2019, 10:14 AM | #17 | |||
2095
Rep 43,350
As far as the mounting bracket goes, it's simply unnecessary. The BMW N54 market is clear proof that the bracket is simply another over engineered inclusion from BMW in order to make it easier for techs to align the downpipe with the turbo and catback. The most popular N54 and N55 downpipes do not have mounting brackets and there are even less mounting points for the catback whereas the B58 has significantly more bracing to eliminate stress from the downpipe and catback. If anything, bracing a moving object to a solid object would create more vibration, not less. Last edited by Tiago@VRSF; 05-13-2019 at 10:48 AM.. |
B58557.50 |
05-13-2019, 10:30 PM | #18 |
102
Rep 128
N55 downpipes are minuscule compared to the B58.
Not sure how you can compare the two, or apply logic befitting one to the other. The B58 oem downpipe also makes use of the flex joint - it actually flexes. You can move it yourself by hand. The VRSF flex joint, in comparison, doesn't flex at all. It's basically a solid joint. Is there a reason why it's so much stiffer than the oem flex joint? Did you consider the fact that any movement in the exhaust mid pipe and backbox would have previously been isolated from the OEM downpipe due to the flex joint, but now that VRSF joint is so stiff, that movement would be directly transferred to the turbo flange connection point? |
eksigned139.00 |
05-14-2019, 06:18 AM | #19 | |
558
Rep 1,457
2024 X3 M40i
2014 BMW M5 |
05-14-2019, 07:21 AM | #20 |
102
Rep 128
05-14-2019, 08:27 PM | #21 |
2095
Rep 43,350
Alpine-F80200.50 |
05-14-2019, 09:36 PM | #22 |
24199
Rep 190,807
Here are some of the reviews we received for the VRSF B58 downpipe
Jarrad Installed on the weekend. Great quality and great service! PABLO The best upgrade and the sound amazing Michael Completely changed the sound of my car and gave it additional power that was previously being choked by the oem downpipe. Highly recommend as the next mod following a tune. Samir It sounds good ❤️ Eric Great down-pipe. Shipped quick and fit like a charm. The B58 sounds amazing with a catless down-pipe! dennis very happy with it at this moment Nic This has been the best investment made for my 340i MPPK. Love this down pipe! Derrick Great product. Just had it installed from my local shop. Sounds much louder with extra performance you can feel. Nick Excellent customer service, they were able to get my product shipped fast after a quick email. Killer product very happy with quality and price! john Beautiful downpipe just needs to come with a gasket Jalene needed gasket should have bin included lost one day trying to find one still am verry happy Isaiah Love everything about it ! This down pipe is worth every penny . Gives the stock exhaust a nice tone. Very good power gain as well. I should have purchased the product sooner ! Highly recommended !
