04-23-2019, 12:56 PM | #1 |
225
Rep 677
spark plugs gap?
I bought a new set of spark plugs. I currently run jb4 map 3 with dp, intake and exhaust. I know these plugs are gapped at .028 from the manufacturer. Should I gap it to .022 for the mods that I have?
04-23-2019, 01:34 PM | #2 |
208
Rep 245
My understanding is it is a function of cylinder temperature/pressure, which is a function of boost. The bolt-ons only matter if you are running higher boost. I don't know what the exact boost needs to be to start needing smaller gaps, but somewhere around 18-20 psi I think. There are a couple of spark plug threads here.
2017 F30 340i RWD // MG Flasher // xHP // CG DS-1 // ZTR ZMP ZCW ZLP
04-23-2019, 06:00 PM | #4 | |
810
Rep 1,454
For clarification, they're 1-step colder for our B58's.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2 |
04-23-2019, 08:47 PM | #6 |
2466
Rep 5,457
Drives: F30
FWIW...
Im running stock gap on the upgraded NGK Laser Iridium plugs. Car runs perfect on Bootmod3 Stage 1 with FBO. Wrestling with the idea of adjusting gap when I go stage 2 but not sure yet. Some report issues which has me iffy. |
04-28-2019, 11:34 PM | #9 | |
139
Rep 467
I think the idea of bringing down the gap is more preventative of blow out. I'd recommend it. I too didn't notice much of a difference, but it's piece of mind for what...$150? |
