      04-23-2019, 05:12 AM   #1
NicR
Drives: 2005 BMW 120i
Sp Daten for 2005 120i E87 with N46 motor
Good Morning,
I hope someone on here can help with the issue I'm experiencing at the moment. I bought a 120i to rebuild and I've noticed recently that the Differential Intake Actuator valve doesn't function nor does it generate a fault code when I unplug it. Same with the MAF sensor.
After a bit of research I figured out that later models and especially the Low end power ones don't have this intake valve and also don't use the MAF sensor. So I suspect that my DME has had the wrong firmware upgraded to it.
I would like to try go back the the original or as close to it as possible. The Dme also has a fault code for "Coding Fault"
Would someone be able to assit me with old sp daten files so that I can attempt to correct this. I'm looking for the 2004 to 2005 files. I'm not sure what version this would be?
Thanks
Nic
Tags
coding, dme, sp daten, winkfp
Search this Thread:
Advanced Search
