04-22-2019, 03:05 PM | #1 |
9
Rep 70
ESys Launcher Help
Hi all, I just purchased an ESys Cable and downloaded ESys and psdzdata, but I'm hung up on a couple of things.
1. It appears I need a launcher for ESys, but the popular option is gone and I can't even find a download link for the program itself. What alternatives are out there? Sub-question, I do see that EsysX is a thing, but I don't even know what to buy from their website to get things going. 2. My car is a 2017 F31, but I downloaded the psdzdata 4.16.40 is this recent enough of a file? If not, where can I find the most recent psdzdata? Thanks in advance! |
04-22-2019, 09:15 PM | #2 |
588
Rep 2,302
Here you can find the Launcher Premium and the latest psdzdata (even though 4.16.40 is enough) (Point 2: Software Installation):
https://www.bimmerfest.com/forums/sh...d.php?t=983244 And to get the Launcher Premium to work you need this little script: https://f30.bimmerpost.com/forums/sh....php?t=1457494 |
04-23-2019, 08:10 AM | #3 | |
9
Rep 70
Do I even need to worry about psdzdata at all if I'm just doing vo coding in Esys? |
04-23-2019, 09:16 AM | #4 |
8245
Rep 16,085
Bimmercode in expert mode is for all intents and purposes E-Sys, you even use the E-Sys cheat sheets to work in expert mode, so there's no need to have both.
04-24-2019, 08:51 AM | #5 | |
9
Rep 70
I'd really like to find a way to make comfort access/closing operate the windows and sunroof as one-touch instead of having to hold the button or the door handle next. I'm also wondering if there's a bigger notification I can get on NBT when I get a text, like the first so many lines of the message instead of just a notification symbol at the top left like it does now. |
08-10-2020, 01:46 AM | #6 |
Rep 19
Hi Guys
If u want Activation Key for E-Sys Launcher PRO v2.8.1 Build 155 you can check this blog I used it and it works https://bmwxcode.blogspot.com/2020/0...-pro-v281.html You need to install Esys 3.30.1 in order for the Launcher PRO v2.8.1 to work with. Also: PSdZData_Full v.4.23.12 Release date 14.07.2020 https://bmwxcode.blogspot.com/2020/0...ll-v42312.html ISTA D v4.24.13 2020 BMW-RHEINGOLD PSdZData_Full Release date 14.07.2020 https://bmwxcode.blogspot.com/2020/0...rheingold.html Cheers! |
