2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Coding Convertible Top
      04-22-2019, 12:28 PM   #1
bclinsure
Drives:
My 2019 2 series IX convertible is awesome but there are some things that need correction. Case in point, the convertible top control gets 'pushed forward' to open the top and 'pulled back' to close it. It's exactly opposite of how it should go. Does anyone know if Bimmercode has a setting to change this? I know it's small and unimportant but it doesn't make any sense the way it is.
Thanks in advance.
      04-22-2019, 01:31 PM   #2
SpaceForRent
Drives: BMW
2018 M240xi  [0.00]
Thanks in advance.
It's emulating a window (Push to open, pull to close). Curiously, it's only done this way for the Convertible tops in the US.
Yes, it drives me crazy as well. I've asked the Bimmercode people last year and they didn't know of a solution then. Haven't ventured into the switch (S55b), but it might be as easy as swapping the wires.
You can see here:
https://www.newtis.info/tisv2/a/en/f...cab/1VnY8rylcQ
https://www.newtis.info/tisv2/a/en/f...ule/1VnYWO6Pav
      04-22-2019, 07:25 PM   #3
BEM-S4
BEM-S4's Avatar
Drives: Dinan M235, Dinan Sport Wagon
There's an aftermarket convertible box that you plug into the harness behind the door card. Forget who makes it. It allows you to switch the direction of the toggle along with a number of other options.
2022 Macan S
2016 F31 328i xDrive Sport Wagon
2006 E46 330ci ZHP Convertible
      04-22-2019, 09:47 PM   #4
M235SDCA
M235SDCA's Avatar
Drives: 16 M235 Vert
The box is made my mods 4 cars. It goes in line with the top control module that is in the rear seat area. You get one touch open / close, changing the control operation, one touch up for all windows, open / close top with key fob, etc. Module isn't cheap but after having it I couldn't do without.
16 M235 Cabrio - BM3, ER CP, Wagner DP & IC, Dinan Intake, MPE, Torqbyte CM5
18 340i F30 mostly stock
      04-23-2019, 09:35 AM   #5
mr. zero
45
Drives: 18 MG/CR M240i Conv 6M
2018 BMW M3  [10.00]
Funny, I look at it as pushing down to put the top down, and pulling up to put it up.
      04-23-2019, 03:49 PM   #6
Climate Changer
Climate Changer's Avatar
Drives: 2018 230i xdrive convertible
2018 230i xdrive co ...  [0.00]
2019 x3  [0.00]
What we all should be looking into is coding the comfort access to work more than 5 ft away.
It's pointless to walk up to the car press the fob and stand outside for 25-30 seconds and wait for the top to go down.
The distance should have been the same as the lock/unlock.
That way by the time you get to your car its done.
      04-24-2019, 03:08 PM   #7
msej449
msej449
msej449's Avatar
United Kingdom
514
Drives: M235i Convertible +LSD 2016
In BMW's defence, the hydraulics and mechanism for the convertible roof are quite powerful. The problem with any one-touch system is if anyone is distracted and puts their hands/arms in the mechanism as it folds. To obviate injury, the system would need additional sensors etc. to abort the movement, and given the roof can be deployed up to 30mph there may be problems in making that work effectively. All in all, I can see why BMW makes the raise/lower button a 'dead man's handle'.
But I agree about the distance thing - as long as you can see the car, I don't see what the problem is in activating the roof from further away.
Also a tip - if you part-lower the roof to clean the tonneau channel and/or the roof storage cavity, be aware that after about 45-60 seconds, it'll depressurise under the weight of the mechanism, and move of its own accord.
2016 M235i Convertible Estoril Blue & Oyster
2023 Peugeot e-208 GT (electric)
      04-24-2019, 11:33 PM   #8
bmtespar
bmtespar's Avatar
Drives: 19 X3 30i, 18 230iX Vert
The problem I have after coding my mirrors to fold upon lock is that with zero delay it will also pop the tonneau latches to start putting up the top if I touch for just a second too long. I wish there was a a way to have to touch door handle longer before the top goes up but have the mirror fold instantly. Anyone?
Current: 20 M340i
Sold: 19 x3 30i X drive, 18 230i X drive Convertible
18 x3, 30i X drive 16 428i Convertible, 16 X1 X drive, 14 i3 Rex, 14 328i, 14 x1 28i X drive, 08 328i, 03 M5, 99 323i Convertible, 00 z3 M Roadster, 99 328i, 00 323i
      04-25-2019, 08:55 AM   #9
Climate Changer
2019 x3  [0.00]
I have my mirrors coded to 1.5 second delay and never had an issue fob or door activating the tonneau. I'm using bimmercode.
As soon as the mirror starts to close let go. Hope that helps.
      04-25-2019, 01:12 PM   #10
BEM-S4
BEM-S4's Avatar
My mirrors work with fob but not with door, used bimmercode as well. Who knows.
2022 Macan S
      04-25-2019, 05:22 PM   #11
bmtespar
bmtespar's Avatar
You do know there are two sets of coding for mirror fold, right? One for fold/unfold via key fob and another for fold/unfold via door handle.
Current: 20 M340i
      04-25-2019, 05:51 PM   #12
BEM-S4
BEM-S4's Avatar
Really? Hmmmm. Definitely worth checking out thanks!
I did this years ago maybe bimmercode didnt have the option then. Although my wagon I did the same thing and it all works.
2022 Macan S
2addicts
