04-22-2019, 09:05 AM | #1 |
125
Rep 258
Tire Pressure
So, what do you believe, what is recommend on the door (32psi) or what the car computer says (46psi)?
Previous: 2005 BMW E60 545
04-22-2019, 09:21 AM | #2 |
329
Rep 533
I'm going with 32-34 cold and it typically runs at about 38 when the tires are warmed up. As the weather warms up we will see 40+ PSI. This is why I run Pilot Alpine in the winter. No way would you want 40+ psi in the 20s on a cold day. Would be like hockey pucks on the wheels for you Canadians 😀
04-22-2019, 09:29 AM | #3 | |
125
Rep 258
04-22-2019, 09:48 AM | #4 | ||
1346
Rep 849
Drives: M8 GC || M5 Comp || X7 40i
2024 M8 GC Black/Black || 2021 M5 Carbon Black/Midrand beige || 2021 X7 40i Amertin metallic with Ivory white merino
2019 M5 F90 || 2018 X5 s35i || 2017 M5 F10 with Arkapovic Exhaust || 2016 535 || 2012 535 hated it after the E60 || 2010 535 E60 - my fav || 2008 528 E60 my first |
CanadianF90M5125.00 |
04-22-2019, 01:32 PM | #5 |
153
Rep 427
Drives: 2019 M5 Competition
Don't forget there are another set of pressures if you'll be going over 100 MPH. Much higher, like 45-46 maybe? Its in the manual.
04-22-2019, 02:31 PM | #6 |
94
Rep 249
Agree with the above post. Are the tires set to >100 mph. I just changed to summer tires and put that setting and got the same recommendation. I changed it to below 100 and then got the 30 something recommendation.
04-22-2019, 06:02 PM | #7 |
407
Rep 2,704
It does not make sense >100 mph, the tire could heat up so much it could blow.
Max rating on my michelin is 50 psi, if you put 46 psi, you will hit 50 psi after 5 miles of driving it unless your using nitrogen gas for your tires. With O2 you could see 52/54 psi on a hot summer run at those speeds., now way I would roll with that. 34/35 PSI all around and good to go. |
04-22-2019, 06:12 PM | #8 |
18966
Rep 10,095
32/33 is what I use.... remember what the actual tire says on the sidewall is the max for the tire not knowing what car its going on. I use the door jam recommendations for speeds under and over 100 but usually under 155 and never fully laden.
2023 BMW M8 Coupe Competition Alpine White
2022 BMW M3 Competition XDrive Aventurine Red 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
04-22-2019, 08:07 PM | #9 | |||
125
Rep 258
04-22-2019, 09:30 PM | #10 | |
153
Rep 427
04-27-2019, 11:18 AM | #11 | |
1816
Rep 1,304
Although, as you point out, there is a max pressure that will cause failure. It all depends on tire and driving style. Do you have any notes as to how high your pressures get when driving? Shawn |
