04-22-2019, 04:29 AM | #1 |
Rep 52
ISTA+ - error in testmodule abl_ges_at5100_zfs
Hi All,
I finally got it up running after a hardware crash , but u I upgraded from an old ISTA 3.6 version to ISTA+ 4.15.16. Everything works except on connection I get the error message: "ERROR IN TEST MODULE ABL_GES_AT210_ZFS a technical error appeared while loading -check if this file exists" Please can anyone help as to how to resolve this? I can still read the car and do the test module but guess an error will be throwing something out. I'm not sure where this should sit or what it does. For anyone having problems - a quick checklist in no order that I did trial and error testing: 1. ensure you save Rheingold in your program (x86) c folder 2. run GUI as administrator 3. make sure SQLDB versions match up to version of ISTA you use or it will throw database errors - 5 files needed 4. Set up adapter per cable you have, I use ENET so can get the car to read without needing IP settings. Thanks Smithie |
04-22-2019, 06:02 AM | #2 |
588
Rep 2,302
In the heading of this thread stands "abl_ges_at5100_zfs".
In your text stands "ABL_GES_AT210_ZFS"? The "abl_ges_at5100_zfs" i found in my 2 versions under .../Rheingold/Testmodule. |
04-22-2019, 08:29 AM | #3 |
Rep 52
Thanks ATZE - I worked it out, sorry for the typo - for some reason I lost the AT5100 in the transfer to the new hard drive. All up and running finally cheers for the support and answers..
