04-21-2019, 05:20 PM | #1 |
57
Rep 153
DIY Oil Change on M2c
7 Quarts of oil - use whatever you like.
1 Oil filter - I used this Mann filter from amazon. Came with the 2 gaskets and copper oil drain plug washer. Put car up on ramps or jackstands. Grab a 17mm wrench or socket - remove oil drain plug. While oil drains, unscrew the filter canister on the top of the motor. I don't have a canister "socket" so I wrapped the canister with some towels and used a large oil filter removal wrench with teeth. I was gentle with the pressure on the canister and the towels help eliminate any marks on the canister housing. Remove the canister Remove the small o-ring with the tip of some scissors or a very small needle like tip tool. Replace o-ring. Remove large o-ring on the canister itself. Again, re-use whatever tool you used to remove the small o-ring. Remove dirty filter, slide in new filter. Screw canister on - i used my hand to tighten it. Back under car and replace 17mm bolt with the fresh washer on it. Refill with 7 quarts of your favorite oil. Clean up and drive it! Last edited by atc5; 04-22-2019 at 02:33 PM.. |
04-22-2019, 07:03 AM | #2 |
2721
Rep 3,335
Thanks for the reminder! I plan to do "intra-interval" oil changes on the M2C like I've always done on my cars, and I think it's very close now at 5200 miles.
I just checked the filter cap, and I'm surprised it doesn't have the standard 36mm "nut" on top. I actually have the filter removal tool in my tool chest however, and it fits perfectly...whew!
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 |
04-22-2019, 10:02 AM | #3 |
2136
Rep 1,324
[QUOTE=atc5;24684531]7 Quarts of oil - use whatever you like.
1 Oil filter - I used this Mann filter from amazon. Came with the 2 gaskets and copper oil drain plug washer. Put car up on ramps or jackstands. Grab a 17mm wrench or socket - remove oil drain plug. Could a Fumoto drain valve replace the stock drain plug? Did you need to remove any large plastic shielding to get at the drain valve. On most cars the shielding is held on by 12 or more pop/ twist fasteners? |
04-22-2019, 11:06 AM | #4 |
this is the way
18143
Rep 8,521
Oil Filter Cap
Torque: 25Nm / 18.43ft-lb S55 Oil Drain Plug Engine Type: S55 Oil drain plug on aluminum oil sump. - Drain Plug Thread: M12x1.5 - Tightening specifications: Replace only the gasket (sealing ring) of oil drain plug. - Torque: 25Nm * Tip: Before jacking up the car, unscrew the oil filler cap. Doing so allows air in which speeds up the oil draining. |
04-22-2019, 12:24 PM | #5 |
4207
Rep 5,728
Drives: 2019 M2 Competition
Anyone have an "expert" opinion on magnetic oil drain plugs? I had one on my n54 engine just in case.
https://www.ecstuning.com/b-ecs-part...BoCd4EQAvD_BwE |
04-22-2019, 12:34 PM | #6 |
2659
Rep 448
Instead of going to the dealer for fluid change OR going to Al's oil barn I rather do it my self for every other change 5k miles, is the "oil extractor" a good choice?
I don't have a garage anymore, I'd like to do it my self instead of grease monkeys or waiting at a proper bmw service place For $50-$100 a cheap extractor will pay for it self in a year or so and save me time not making appointments Draining properly or use of a extraction tool? And what about the drain plug do I need to replace anyway after every change or leave it when the 10k mile free change is done at the dealer |
04-22-2019, 12:43 PM | #7 | |
826
Rep 1,015
04-22-2019, 01:05 PM | #8 |
2865
Rep 3,842
04-22-2019, 01:11 PM | #9 | |
this is the way
18143
Rep 8,521
Even if it's not that much the stuff in the bottom is the thick sludge you want to drain out. Old school oil change is still the best. |
NEfan5082658.50 |
04-22-2019, 01:14 PM | #10 | |
2659
Rep 448
Forum please help, extractor sound to good to be true, eliminating ramps, going under the car (risk LIFE) and time wasted going to Service appointments "Joe" the fast oil change guy without appointment does a decent job but he might get grease/dirt inside the car and or on the car bumper/hood from leaning in Happens all the time, I don't care on my work trucks Edit: TAG, makes a good point, what I was thinking |
04-22-2019, 01:28 PM | #11 | |
57
Rep 153
I'm sure you can use the fumoto. That said, the drain bolt is 100% unobstructed. No panels, no shields, just right there smack dab in the middle. Couldn't believe how nicely available the drain plug is. Re: questions about extractor - yea without a dipstick guess that's not really an option! |
ContactPatch2136.00 |
04-22-2019, 01:49 PM | #12 | ||
86
Rep 200
Drives: 14 Honda Civic Si, 17 BMW M4
Edit: I use it on a Mercedes Benz, totally forgot this car doesn't have a dipstick. |
04-22-2019, 01:55 PM | #13 | |
2865
Rep 3,842
atc556.50 |
04-22-2019, 01:55 PM | #14 |
Rear Admiral
1485
Rep 1,706
Drives: Bavarian Milk Wagon
Couple of Tips (at least things I've always done and are considered good practices):
1. put thin layer of oil (new), with your finger, on the larger, filter housing O-ring, after installing the ring and just prior to screwing it back in. I don't think this is mandatory but it helps create a better seal. 2. Pour a bit of new oil into the new filter while it's in the housing, just before installing. Enough oil to soak the filter if possible. Also not mandatory but from my understanding, this helps minimize time internals are "ran dry" and "primes" the oil filter. Yes, it's hard to do this without spilling a bit of oil, but-a rag. |
Rommel428.00 No_curebimmer637.50 |
04-22-2019, 02:05 PM | #15 |
Rep 14
As some people have mentioned, there isn’t a dip stick tube to use as a way to access the lower section of the oil pan. So using an oil extraction device isn’t an option.
To the person asking how much oil is still left stuck in the oil pan after letting it drain, it’s less than a 1/4 - 1/3 of a qt. |
04-22-2019, 03:31 PM | #16 | |
“One finds limits by pushing them”
123
Rep 529
infinitekidM2C4206.50 |
04-22-2019, 03:51 PM | #17 |
2659
Rep 448
Since my dealer "let" a employee joyride my car Dunkin Donuts, lunch and TO GAS up my car as a curtesy I'm less likely leaving my car @ dealers never mind oil change shops
I could see some bull shit response (just checking the car for safety) again, if it was my work truck or regular grocery getter I wouldn't care I rather do the simple maintenance my self limiting grease monkeys access Note: firmly told dealer not to drive the car off the lot, don't wash it don't put gas in it but they couldn't handle my request No need to prep the car, plates was mailed in and inspection sticker I was handling (out of state) no reason to drive other than a 15 mile joy ride (bull shit) with a rock chip THE cherry on top |
04-22-2019, 05:51 PM | #18 | |
4944
Rep 4,976
Wife's Car: 2020 X4M Competition, Alpine White on Black Alcantara and Biege
Current Car: 2018 F80 M3CS, SMB, DCT, ZEC, MPE Recently Departed: 2020 F87 M2C, LBB, ZEC, 6MT (Euro Delivery Aug. 29, 2019, totaled by an idiot in a Camry who then ran from the scene) Wife's Prior Car: 2018 F80 M3, Yas Marina Blue, DCT, Black 19s, Carbon Structure Anthracite Cloth/Leather Combination, Driving Assistance Package (Euro Delivery Oct. 9, 2017) |
cptobvious2531.50 |
04-25-2019, 03:24 PM | #19 |
1860
Rep 2,104
Yes, the oil extractor is not an option on these cars. BMW's used to have 2 dipsticks; now they just have 1
Lake Effect24.00 |
05-30-2020, 04:16 AM | #21 |
1717
Rep 1,899
I saw that oil recently released but couldn't find any technical sheets on the oil from the manufacturer. Now Motul is typical highly regarded but it just struck me as odd that we can't find any technical specs like Pennzoil and a few other companies have.
The price point for it currently is amazing though |
05-30-2020, 08:26 AM | #22 | |
63
Rep 187
looks like only 5w 30 for the LL01 FE application. |
