04-15-2019, 01:50 PM | #1 |
16
Rep 96
B58 Silicone Turbo Inlet w/ oem air box
Hello Everyone,
I'm starting this thread to find out what the interest is here on the forum for a custom single pipe intake tube to turbo inlet that still uses the factory air box. I'm talking with a silicone hose manufacturer now to understand what is involved in making one. This build would require a 3D model, tooling costs and a 25 qty minimum buy. I personally would like to keep the factory air box and filter as it's known to flow very well and have a high filter efficiency. Is there anyone else interested in purchasing a custom silicone pipe that connects the factory air box to the turbo? The goal of this design would be to remove the 4 resonators built into the factory piping. It would turn a two price design into a single price design. This would theoretically flow better and provide more induction/turbo noise. After the hose is made I would use it to do a dyno comparison to see if power was gained or lost and what the sound change is. This is in a very elementary stage and this post is only to gage interest. Attached is the factory hose assembly that this design would replace. |
04-15-2019, 02:01 PM | #2 |
558
Rep 1,457
Practically something similar to this? https://www.moddedeuros.com/products...wagen-alltrack
This is used on the MK7 GTI its a inlet hose that connects from the airbox to the turbo inlet.
2024 X3 M40i
2014 BMW M5 |
04-15-2019, 02:18 PM | #3 | |
16
Rep 96
04-15-2019, 02:41 PM | #5 | |
120
Rep 410
https://shopeurocompulsion.net/colle...meo-giulia-2-0 LOL way overpriced |
04-15-2019, 03:07 PM | #6 | |
16
Rep 96
04-15-2019, 04:56 PM | #8 |
62
Rep 132
Drives: OG M2
I'm interested
04-15-2019, 05:15 PM | #9 |
11
Rep 32
Upper baffle removed, all you really need...
04-15-2019, 06:13 PM | #10 |
135
Rep 234
04-15-2019, 08:02 PM | #11 |
187
Rep 458
04-15-2019, 08:19 PM | #12 |
16
Rep 96
04-15-2019, 08:20 PM | #13 | |
16
Rep 96
04-15-2019, 10:50 PM | #15 |
11
Rep 32
Found this setup on You Tube over a year ago, just VHT primer and wrinkle finish to the pipe to get rid of the aluminum finish. Sounds and looks better then any other intake setup in my opinion.
Spectre Performance 9575 3.5" Flex Boot Spectre Performance 95611 Black 3.5" x 3" EPDM Coupler Spectre Performance 9599 3.5" Aluminum Mandrel Elbow |
Catman411519.50 |
04-15-2019, 11:35 PM | #16 |
135
Rep 234
Thanks, I also noticed that bigboost turbo actually makes this Intake pipe but it’s bundled with their turbo kit. I reached out to them to see if they will sell separately and will post back.
04-15-2019, 11:51 PM | #17 |
11
Rep 32
04-16-2019, 11:37 AM | #19 |
Cheapskate
4450
Rep 4,993
I like the idea. It maintains the OEM cold air induction, OEM MAF, etc. Just cleans up the rest.
I'd be concerned about install though because the 2-piece design likely helps with accessing the bungs on the bottom. Also, I wouldn't be interested if the price is $200+. |
04-16-2019, 12:39 PM | #20 | |
16
Rep 96
kern4174449.50 |
04-16-2019, 02:41 PM | #21 | |
558
Rep 1,457
2024 X3 M40i
2014 BMW M5 |
kern4174449.50 |
04-18-2019, 10:06 AM | #22 |
659
Rep 1,239
Id be interested.
I might measure up the top half and change it out and see if it opens up the sound any more as it certainly seems the easiest bit to change out, and it would be visually the biggest change. |
BornATeste16.00 |
