Bimmerpost
4 Series
Technical Topics Wheels and Tires Vossen wheels
      04-12-2019, 01:14 AM   #1
Patrickske
Drives: BMW G20
Vossen wheels
New HF3
Appreciate 2
louscrw42.00
      04-12-2019, 10:36 AM   #2
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
Welcome.
Very nice, I assume those are 20", so what size tires did you go with?
      04-12-2019, 10:51 AM   #3
Patrickske
Drives: BMW G20
Originally Posted by remmib View Post
Welcome.
10 inch in the back and 8,5 front .
265 30 20 back and 225 35 20 front
      04-12-2019, 10:54 AM   #4
Patrickske
Drives: BMW G20
Welcome.
Not easy , no wheels available for the moment with the right offsets ( ET) so forced to calculate a little and go for spacers 🤔
      04-12-2019, 11:33 AM   #5
louscrw
42
Drives: 2022 m340i
Not easy , no wheels available for the moment with the right offsets ( ET) so forced to calculate a little and go for spacers ��
What are the size and offsets of those wheels and how big of a spacer did you use?
The OEM M performance 794M 20” specs are:
(F) 20x8 ET27 225/35/20
(R) 20x8.5 ET40 255/30/20
I sent a message to Brandon VMRWheels and he suggested the following:
Square: 19x8.5 ET35 225/40/19
Staggered: (F) 19x8.5 ET35 225/40/19 (R) 19x9.5 ET45 255/35/19
I can’t decide what I want yet. I’m hoping someone figures it out. I don’t want to be the guinea pig
      04-12-2019, 12:57 PM   #6
Patrickske
Drives: BMW G20
i have 8,5 front ET 20 and the tyre is still inside te fander ( 2mm in)
Rear 10 inch ET 40 and the tyre is flush
      04-12-2019, 01:28 PM   #7
louscrw
42
Drives: 2022 m340i
Patrick,
So you have:
(F)20x8.5 ET20 225/35/20
(R)20x10 ET40 265/30/20
Are you using spacers? Does it rub on anything?
      04-12-2019, 01:35 PM   #8
Patrickske
Drives: BMW G20
Originally Posted by louscrw View Post
Patrick,
So you have:
Hey all ,
My front ET rim is 40 + spacer from 20 mm what makes ET 20 .realy good in the front .
Rear the rim is ET50+ spacer from 10 mm. Not less available . But this realy max . It's not out but really on the edge. Better would be 2 or 3 mm less . But ok , looks nice . KW suspension not yet available. And now, no rubbing !!
      04-18-2019, 04:38 PM   #9
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Right now, it's looking like we'll stick with 8.5 ET35 front and include some spacers just in case. In the rear, we'll change from ET45 to ET35 to bring them out a little bit closer to the fenders. The 9.5 ET45 is 8mm more aggressive than the stock M Sport 8.5 ET40, but it seems like there's enough room to squeeze the 9.5 ET35 back there. The 9.5 ET35 rear will be 1mm less aggressive than the 10 ET40 shown above.
      09-09-2019, 10:14 AM   #10
onefastdoc
115
Drives: 2016 F80 M3
Will a 275/30/20 fit in the rear (on either the ET40 or ET35 offset wheel)?
      09-11-2019, 11:45 AM   #11
cidair
cidair
cidair's Avatar
Sweden
83
Drives: BMW 435d xDrive
I´m very curious about this too.
I want to use 9x20 ET 40 with 275/30 in the rear.
2016 435d xDrive
Previous:2019 M340i, 2014 335dx,2012 M5,2011 550ix,2008 M3,2007 330xd,2005 M5,2004 545iA,2000M5.
      05-31-2020, 02:09 PM   #12
JetPump
Drives: BMW M340i RWD
That setup looks great. I guess I’ll check out VMR’s website. Thanks for the post and pictures.
g20
