Stutter or Misfire at high RPM
04-04-2019, 08:23 AM | #1 |
Rep 8
First time poster, long time lurker. Experiencing stuttering and misfires at the top end, I have just a crappy log and will try to get a better one, but it hits the major variables.
Stuttering came on after turbo inlets, was running MHD v8 E30 Stage 2+. Reflashed to MHD v7.1 E25, same issue but slightly less. Manually tested the fuel and mixed for E33, mixed it back down to E25 with a lot more 93, same issues. Fuel pressures look acceptable on WOT, low pressure pump seems to dip below acceptable limits. I've read below 60 is a bad sign, this hits 50psi. Thoughts are welcome, even if random. Planning on getting a custom tune once I find the stuttering problem, didnt want to have mechanical/program issues while I tune her right. Secondary point, I did get a code the first time I went WOT after inlets for Cyl 5 Misfires. I cleared adaptations and started diagnostics from there, thats why I think it could still be a less bad misfire that exists. Mods and specs - BMW 335i xDrive E92 N54 MHD 7.1 Stage 2+ E25 Tune XHP Transmission Tune - Stage 2 Injen Dual Cone Intake VRSF 7" HD Intercooler VRSF Lower Charge Pipe VRSF Upper Charge Pipe VRSF 3" Catless Downpipes VRSF 3" Turbo Inlets Injectors, Coils, Plugs have less than a few thousand miles on them. Walnut blasting also performed very recently. Somewhat relevant log, will try to get a better one (3rd pull getting on the highway) when able. https://datazap.me/u/viralblack/log-...-20&zoom=0-421 |
04-04-2019, 09:47 AM | #3 | |
Rep 8
The desire to not be a pain in someone elses ass has me trying to make sure every I is dotted and T crossed before I start occupying their time professionally. Ideas and comments are always welcome, could easily lead to answers |
04-04-2019, 09:50 AM | #4 | |
641
Rep 1,245
My other side of that would be, they have a pretty good idea of what they need to do based on a datalog and your basic setup. So sending a good log of your current setup, list of mods and obviously let them know the issue you are chasing. They could send a base map with the bulk of the stuff you need to start with a good running map to properly troubleshoot. |
