To prime or not to prime?
04-03-2019, 08:25 AM | #1 |
71
Rep 628
Drives: ...when not replacing gaskets
Hey guys
I'm getting ready to repaint the old silver stock rims on my TiAg 335i as I want to go with a gunmetal color. They're in fairly good shape so my hope is to get away with lightly wet sanding the paint then applying the new color directly over. However, I'm not sure if it would better to prime the rims first. Any thoughts from the painting-experienced members would be greatly appreciated? |
04-03-2019, 09:07 AM | #2 |
Driving cars and riding bikes really fast
285
Rep 1,002
I've painted a few rims and followed all the steps for a DIY application. Prime the rims. It helps helps the new color adhere to the surface. Nothing is better than powder coating though! The durability and rust prevention is unmatched. It's more expense but if you're keeping the car I'd consider it.
335i, sport pkg, 3 pedals, Blacked out, LED markers, OZ Ultraleggera wheels, Firestone Indy 500s, x-pipe, vibrant 1792, PE mod
MHD stage 2+, BMS DPs, ARM charge pipe, Tial BOV, ARM FMIC, dual cone, CSF radiator, M3 control arms, sways, HAWK pads. https://www.strava.com/athletes/8309149 Follow me on Strava |
04-03-2019, 10:01 AM | #3 | |
71
Rep 628
Jaronbwall284.50 |
04-04-2019, 08:22 AM | #4 | |
285
Rep 1,002
I'd clean the rims with Dawn Dish Soap and remove any oils. Either way good luck man!
04-07-2019, 04:03 AM | #5 |
71
Rep 628
Yes, thanks. I'm using Duplicolor wheel paint (graphite/gunmetal colour) with a satin clear coat. I think that gloss might make the wheels look cheap.
04-08-2019, 02:39 AM | #6 |
Rep 3
if there is any curb rash, sand with 80 > use metal filler JB weld would work> sand with 120>200>300> prime > sand with 400-600 then paint.
if the paint is messed up, save yourself the trouble, use a aircraft paint stripper, remove all old paint, use wax and grease remover. sand with the grit recommended on the primer can, prime, and sand again if needed. final step is to paint. save your finger and pick up a spray can grip. |
Jaronbwall284.50 |
