04-01-2019, 09:48 PM | #1 |
492
Rep 675
possible to add HK sound to Hifi X2?
We bought an X2 M-Sport for a DD. Hunting for an X2 without a sunroof was a task but I found one. Its a very enjoyable ride to and from work, and it keeps me from putting miles on my M3. The only downer is the sound system is just the regular "Hifi". The curve has huge gaps in it. It needs subs, and its missing about half of the mid-bass band.
I know this question gets asked about every model in the BMW lineup, but I haven't seen it here yet: how difficult will it be to add the top of the line sound to this ride? Are the wires in place for the extra speakers and the upgraded amp? Will there be coding necessary? I'm betting there will be, since there's no EQ in the iDrive menu for the audio, just basic tone controls. |
04-02-2019, 06:37 AM | #2 |
110
Rep 394
04-02-2019, 09:17 AM | #3 |
492
Rep 675
04-02-2019, 10:48 AM | #4 | |
110
Rep 394
I had to do a custom order to get the combo I wanted because the dealer had almost all standard HiFi x2s which I thought was weird and the difference to me in sound quality was substantial. |
04-02-2019, 03:40 PM | #5 |
Rep 13
I will advise to look for something else, I just upgraded to aftermarket Audison equipment (PRIMA), it's a huge difference from Hi-fi and actually from HK itself (I got HK on a z4 and Audison it's even better)... you should check that option out.
04-02-2019, 04:28 PM | #6 | ||
492
Rep 675
I'm truly surprised to find an X2 without a sunroof and without nanny systems. I'd really like to have PDC, and I'll probably add it before the end of the year, but its kind of a trick to get that without getting all the warning systems, HUD, and other nonsense that comes in that package. No dealer is going to order a car like that for stock. It'd be like finding a 6MT E46 M3 with PDC. Rare as all could be. |
04-02-2019, 04:34 PM | #7 | |
492
Rep 675
Now, if you could talk another X2 owner into upgrading their H/K to Audison or something else, I'd be able to take their amp and drivers off their hands. Whad'ya say? You in? |
04-05-2019, 02:25 AM | #8 |
333
Rep 1,642
Have a look in realoem. Of course, in addition to the different speakers, there's some differences in things like the door trims (to accommodate the extra tweeter in the rear doors). Also the amp is different, but could perhaps fit in the same location/bracket?
The dash board has the centre speakers that the base model doesn't. The tweeters on the front doors have a different grille. In fact so do all the visible speakers in all doors. Not sure about the 2 floor mounted subs, whether the grille is already there, or is it just a cavity? cheers
2019 X3 M40i, Sophisto grey, H/K, pano
Previous: 2019 BMW X2 Msport, Mineral Grey, Adaptive Suspension, H/K Previous: 2009 335i LCI, Bluewater |
04-06-2019, 04:45 AM | #9 | |
678
Rep 910
Fully retrofitting a HK system is possible and they come up regularly for sale. If you are lucky you will have already have the optical cable running from the HU to the rear of your car., it is easy to spot, the wires are green and twice as thick are copper versions. Most audio installers would have no problem retrofitting the HK system for you but it would be expensive, if only because you would need two new front door trims and two replacement rear door panels for the tweeters (although they could be placed next to mid-range but would be hidden and loose some dynamic effect). Whether you should do HK upgrade or go for after-market alternatives, will be a very personal choice, imo you should at very least take some music samples and listen to the systems in-situ. Some people like the stock HK (I do for example) but many audiophiles do not rate it and prefer alternatives. As I believe dianebrat and others have mentioned, the F48 HK system is dumbed down so you will not get graphic equaliser but it is night and day compared to base system. For my own retrofit, I found that the HU itself provides respectable sound, you will not get higher volume of separate amp, just replacing speakers will provide a dramatic improvement (especially if you also add some tweeters). If I would recommend going and listening to this type of set-up (for example focal) before committing to a full-blown install. The HK front door trims are worth fitting just for the cosmetic improvement and these two tweeters alone dramatically improve range, this would be, IMO, the most effective way to get material improvement. Good luck, let us know what you choose. Last edited by MJE60; 04-06-2019 at 05:30 AM.. |
11-22-2019, 05:15 PM | #10 | |
492
Rep 675
Would you happen to know the build codes for the various stereos? Obviously I don't have the top stereo (HK) but I'd like to know which of the others I do have.
Dinan Stg II Suspension Remus Race Gintani CF lip / CF quarter fins Vorsteiner Type II CF Diffuser BMW Performance CF Spoiler / black fender gills / black kidney grilles / CF mirror cover Speed Element GTS CF side skirts M3 GTS door sills Lux Angel Eyes body color reflectors Alex@Alpine Stg I tune AA filter
11-23-2019, 10:40 AM | #11 | |
678
Rep 910
The easiest way to tell, is this, if your car has HK you will have HK tweeter in front window surround and in rear door cards. If you do not have then next check is - do you have. A central dash speaker? -if yes you have the BMW middle upgrade with dedicated amp and slightly better quality speakers. if not then you have the basic 6 speaker system. If you do have a central dash speaker then you can switch the BMW amp for HK one and upgrade the speakers. The amp is hidden in the boot/trunk behind left hand side panels. If you just have basic system with no separate amp the. You can still upgrade the six speakers nd also retrofit HK tweeters. |
11-23-2019, 10:57 AM | #12 | |
492
Rep 675
The HK system, if its like the previous generations, has a separate amp channel for each driver. (The E36 one for example had 10 channels, 3 for each front corner and two for each rear, so the whole system was actively crossed at the amp instead of passively crossed at the corners, with all the attendant problems that creates.) I think the HK system has 4 or 5 more speakers in it than the lower system(s), so if I put the HK amp in the slot isn't there a problem with channels running to a dead end and therefore holes in the frequency response? Or did HK go back to a proper 4 corner topology with passives at each corner?
