03-31-2019, 06:51 PM | #1 |
2589
Rep 2,432
Drives: 2021 M2C
ZHP LSD
I've never had an LSD on any of my cars, but WOW what a difference it makes in cornering! You can pretty much get away with anything when throwing this car around corners! I love it!
03-31-2019, 07:54 PM | #3 |
2589
Rep 2,432
Drives: 2021 M2C
03-31-2019, 08:23 PM | #5 |
2589
Rep 2,432
Drives: 2021 M2C
05-02-2019, 09:47 AM | #8 |
Rep 5
LSD ON ZHP 2018 340i
Hi - I have a ZHP 2018 340i Melbourne Red (ZHP on window sticker). I was advised has LSD... but when I raised the car and turned one rear wheel forward the other wheel turned the opposite direction - not the same direction forward. According to some posts, this suggests no LSD...? I'm confused. Can anyone shed some light on this for me? Thanks
05-02-2019, 09:57 AM | #9 |
Rep 5
05-02-2019, 10:11 AM | #10 | |
245
Rep 2,387
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
05-02-2019, 10:22 AM | #11 | |
Guy with a car
98
Rep 224
15' 435i BSM on CR // BM3 Stage 2 93 OTS // NGK Plugs Gapped 0.023" // VRSF Catless DP // CTS Turbo Intake, CP, FMIC // AWE Tuning w/ Perf. Midpipe // BC Racing BR Coilovers // Apex EC-7 // Michelin PS4S // Plus a shit load of carbon
05-02-2019, 11:24 AM | #12 |
2589
Rep 2,432
Drives: 2021 M2C
I definitely have the LSD on my car as it shows on my window sticker and I notice it when driving. I also have an email from BMW stating it has the LSD. Are you sure it's not there?
05-02-2019, 12:48 PM | #14 |
3510
Rep 2,044
05-02-2019, 03:19 PM | #15 |
77
Rep 81
My understanding is that the eLSD on the 340i attempts to act like an LSD by using your brakes. If the eLSD detects that one wheel is spinning too much, it applies the brakes to that wheel in attempt to help gain traction. The mechanical LSD can distribute the power to the wheel that has the most grip without applying any brakes. Thus, you shouldn't experience any slow down through corners.
05-02-2019, 03:41 PM | #16 | |
2589
Rep 2,432
Drives: 2021 M2C
05-02-2019, 03:57 PM | #17 |
Guy with a car
98
Rep 224
Thanks for catching my slip up haha, my inner drift demon way typing that out
05-02-2019, 04:02 PM | #18 |
Rep 5
My question is for F30ZHP... Mine lists ZHP on the window sticker and is the same Melbourne Red color as yours and same 19 inch rims as yours... That's why I'm curious... If your car is up in the air and you spin one wheel forward, does the other wheel spin opposite direction or same? Thanks
05-02-2019, 04:11 PM | #19 |
518
Rep 891
I believe since the M Performance LSD (included with ZHP) is a clutch based system it won't lock until the car is under power and certain conditions are met.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
05-02-2019, 04:13 PM | #20 |
Rep 5
My question is for F30ZHP... Mine lists ZHP on the window sticker and is the same Melbourne Red color as yours and same 19 inch rims as yours... That's why I'm curious... If your car is up in the air and you spin one wheel forward, does the other wheel spin opposite direction or same? Also mine is auto trans. Thanks
05-02-2019, 04:25 PM | #21 |
Rep 5
If the LSD is clutch based, then is it possible I do have LSD as stated on my window sticker - even if if car is raised and wheels spin in opposite directions when one is pushed forward?
05-02-2019, 04:31 PM | #22 | |
2589
Rep 2,432
Drives: 2021 M2C
My car is an 8 speed auto, which most like means if I get it up on a rack, and the car is in neutral, I'm not sure what would happen. |
