The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Will 1qt more engine oil damage the engine?
      03-26-2006, 10:39 AM   #1
chicago88
Drives: 2006 BMW 325 Xi
I have e90 325xi
I have that famous engine oil sensor problem. of course I found it out after added 1qt of Mobil1 to it.
My dealership is about 15miles away..
The question is to you guys is
Should I tow it there ? or Is it okay to drive it there with extra 1qt of oil?
Please let me know what you guys think....
thanks in advance
      03-26-2006, 10:46 AM   #2
no1sportz
no1sportz's Avatar
Drives: 2008 335i
Can you drain the quart out? I would not recommend starting the engine at all if in is over full. Operating an engine with excess oil is far worse than running it low. If you have no way of draining the oil then I would have it towed.
08 335i Black Sapphire...current
07 335i TiAg...gone
06 330i TiAg...gone
05 ///M3 Imola/Black...gone
04 ///M3 Carbon Black...gone
      03-26-2006, 11:08 AM   #3
Ryan@Motorwerks
Ryan@Motorwerks's Avatar
48
Drives: X3M
If you are a DIY type of person, then just drain all the oil(it would be somewhat difficult to only partially drain it, but I've never tried that before.) by taking the screw out of the oilpan, and then just put in the proper amount of new oil, or just get it towed to a dealership. Driving with too much oil is a very bad thing for a car.
      03-26-2006, 11:18 AM   #4
ben1364
14
Drives: E90 330iA
Originally Posted by chicago88
I have e90 325xi
thanks in advance
My advice is to call the dealer and talk with the Shop Foreman or Service Mgr. if possible, rather than a service writer. Don't know about the current engine family but lots of folks add an extra quart of oil to E 36 M3s for driving schools, etc. Of course it is easier to remove excess oil from engines with a dip stick. I can't fathom why BMW went with the electronic gizmo. They should know better!
      03-26-2006, 11:35 AM   #5
fletcher969
Dad: "Can't never did nothing"
fletcher969's Avatar
8
Drives: '96 Camaro
I have, in my 30 years of driving, for whatever reason(s) (usually a malfunctioning oil sensor and a not-so-easily read dipstick) put an extra quart of oil in engines before, and I've been privy to a dozen or so other people who've done the same without incident. I can't speak about the E90's engine specifically, but my guess is it would be perfectly fine for a 15 mile drive. Before I opted for the expense of a tow, I'd call the dealership, and speak to somebody who can tell you for sure.
2006 330i: SG/Blk-Blk-Burl/6MT/ZSP/Heated seats/Sat prep
01-26-2006: Ordered Vehicle
02-01-2006: Production Start
02-06-2006: Production End
02-09-2006: Arrived at POExit
02-13-2006: Transit - Don Juan
03-01-2006: Unloaded in Charleston
03-02-2006: VPC
03-06-2006: Arrived at dealership
03-08-2006: Took delivery
      03-26-2006, 11:43 AM   #6
e36
101
Drives: BMWs
too much oil is definitely bad.
      03-26-2006, 11:58 AM   #7
bsjd00
bsjd00's Avatar
Drives: e90
My recommendation - have it towed to be on the safe side, but have the DEALER (well, BMW) pay for the tow. You added oil because the car told you to do so. Therefore, BMW is responsible for the cost of the tow, not you.
You recently bought a $40,000 car that malfunctioned. The dealership should be rolling out the red carpet for you.
If your Service Department or BMW Roadside Assistance refuses to pay for the tow, call your salesperson and tell them that you expect better from a new BMW - and that if this isn't resolved to your satisfaction, you won't buy from him again.
      03-26-2006, 12:01 PM   #8
Lost Rider
Lost Rider's Avatar
Drives: R NineT, X1
2014 BMW R NineT  [0.00]
2015 X1 xdrive  [9.00]
I would call the dealer first.
Good luck.
      03-26-2006, 12:35 PM   #9
chicago88
I've called BMW road side last night and told them I've added 3qt instead of telling the truth(1qt) .. they said they will pay for the tow but It was saturday
so car will sit there for one day on there open parking lot. I told them I would call them back on monday.
I guess I'll call the dealership first tomorrow, looks like I'm getting a free oil change that I was going to do it myself.... car has 1200 miles
thanks guys for your input.
      03-26-2006, 12:42 PM   #10
Ghunger
Ghunger's Avatar
Drives: 330i
I have e90 325xi
thanks in advance
Just wondering, but how do you know you have the oil sensor problem. I'm partially wondering cause I want to know what to look for and partially because I've heard Bimmers burn through oil a little bit and you could actually just need oil.
330i Monaco Blue, Terra /w aluminum trim, SP, PP, CA, PDC, Nav, Folding Seats, Sat Prep
European Delivery Blog
Picture Gallery
      03-26-2006, 01:12 PM   #11
chicago88
simply I have no oil leak what so ever. car has only 1200miles
and after I added 1qt of oil just like the car ask me to do It still says add 1qt of oil... the gage shows the oil level at minimum.
and after I searched a little bit I found out that oil sensor problem for e90 is pretty common.
      03-26-2006, 02:13 PM   #12
ClydeC.
Drives: '06 330i
Did you re-calibrate your oil level sensor?
"When you are prompted by the sensor to add 1 quart of oil, shut off the engine. Power on the ignition (note - DO NOT START THE ENGINE). Scroll through the display until you have the Oil check menu. Perform a control check on the oil level, shut off the ignition. Now add the appropriate amount of oil. After adding oil, drive the car - BMW states that this could take between 6 and 23 miles. The level sensor should recalibrate during this period."
      03-26-2006, 09:01 PM   #13
a burrito
Drives: Urus, 958.2 TTS, 997 S
No it will not. It will however hurt your gas mileage.
Peanut Butter Chunky
