03-29-2019, 03:33 PM | #1 |
2589
Rep 2,432
Drives: 2021 M2C
Break in period..Who's right & who's wrong?
The dealership I bought my car from said with all M cars or M tuned cars, they do not need to be broken in and you can drive them like you stole them.
But is he right? I've been doing my best to keep RPMs under 5K but it's hard. I know there is some 1,200 mile recommendation from BMW for break in, but should I follow that? Just looking for some concise answers. |
03-29-2019, 04:21 PM | #2 |
8245
Rep 16,088
What does the manual say?
TodmordenLad2875.50 |
03-29-2019, 04:23 PM | #3 | |
6659
Rep 15,858
03-29-2019, 04:43 PM | #4 |
5886
Rep 10,256
03-29-2019, 04:48 PM | #5 |
2589
Rep 2,432
Drives: 2021 M2C
03-29-2019, 05:49 PM | #6 |
2020 Z4 M40i - 2022 M4C Convt
3129
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
The engineers who designed, built the car & wrote the manual vs some car salesman. Why even ask the question?
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
03-29-2019, 06:34 PM | #7 |
212
Rep 231
This might not relate exactly to BMW, but I know of a few engine builders for other brands that have you break the engine in as you would drive it. Going to race it most of the time? Break it in at the high RPMs that it'll be at most of the time. I know that I have driven a few cars that have had a high load recorded break in procedure and they typically feel stronger at high loads.
The one thing that is NOT accounted in my personal experience is the total longevity of those motors. Since the ones that haven been broken in like that are typically run hard. With modern day metallurgy and lubricants, I wouldn't worry about it. But I would as others mentioned change the oil at a much shorter interval for the first few thousand miles.
2015 F30 335i EBII MSport
M Perf Exhaust | M Perf Brakes | M Perf LSD | CTS CP | CTS Catless DP | FMIC | BM3 Stage 2 93oct | 20" 405m | 10/15mm Spacers | KW V3’s | Vorshlag Camber Plates |
03-29-2019, 06:38 PM | #8 | |
2589
Rep 2,432
Drives: 2021 M2C
03-29-2019, 06:41 PM | #9 |
839
Rep 440
Drives: 2013 335i xDrive
Way back in the old days a break-in period was required for the piston rings to seal properly. Cylinder honing technology required the rings to do the final "hone". It was standard practice to change the break-in oil at 1000 miles because the rings had honed so much material off the cylinder walls and had sealed so poorly while doing this final hone the oil was dirty.
But now cylinder honing technology and piston ring materials/manufacturing methods have advanced so the rings are seated almost as soon as it is fired up. As others have said - the manual has the knowledge you seek.
I'm not completely useless, I can be used as a bad example.
03-29-2019, 06:47 PM | #10 |
3129
Rep 5,264
I built a sh*t load of engines over my lifetime. There is a difference for engines that will be torn down vs something you want not to look at for 100,000 miles.
Everybody gets into "mine is bigger than yours" on stuff like break-in, oil changes, octane etc. They also tend to forget one very major point on a passenger car engine. Its not just a case of doing a break-in of an engine on a dyno you are breaking-in the whole car. Tires, brakes, shocks, differential, transmission, alternator & right on up the line to every moving part on the car. 1200 miles is no big deal to sit out running WOT or high RPM under load its all part of growing up. FWIW the only BMW's that need a early oil change, 1.200 miles, are the true "M" cars because of additives they use in assembly. What cause very early oil changes in the old days was the liberal use of molybdenum disulfide paste as an assembly lube. The paste would quickly plug up the oil filters cause dirty oil unfiltered oil to circulate through the nice new engine.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT Last edited by BEAR-AvHistory; 03-29-2019 at 07:02 PM.. |
03-29-2019, 06:48 PM | #11 |
247
Rep 776
according to the youtube videos of BMW production, the car goes on a dyno before it leaves the factory.
I say to vary the engine speeds but keep out of WOT for the first 1k or so. Change the oil at 2k miles +/-. |
03-29-2019, 07:36 PM | #12 |
10744
Rep 3,690
This is one of those things that will be debated until the end of time but there's a reason why every manufacturer gives you a break in period. That being said, don't read into it too religiously either. If you go slightly over 5k or even go WOT throttle a few times during break in, you won't hurt your engine.
03-29-2019, 07:40 PM | #13 |
2589
Rep 2,432
Drives: 2021 M2C
Good advice! Thanks all!
03-29-2019, 08:32 PM | #14 |
1599
Rep 3,748
Like the new Acura NSX. Factory already break in the engine so....should go right ahead drive it like your stole it.
Nowadays I wonder if the factory should break in the engine before installing it. It should state on the sticker factory break in Done. |
03-29-2019, 09:39 PM | #15 |
8245
Rep 16,088
03-30-2019, 12:52 AM | #17 |
3129
Rep 5,264
BMW is running an engine spec checkout not a break-in on their dynos.
Kevin
03-30-2019, 09:46 AM | #18 |
Just Copacetic!
177
Rep 616
So what did you find the manual says to do?
'01 X5 3.0 AlpWhite
'16 428i GC AlpWhite '19 230i MSptPkg AlpWhite |
03-30-2019, 10:17 AM | #19 |
2589
Rep 2,432
Drives: 2021 M2C
03-30-2019, 11:32 AM | #20 | |
128
Rep 262
03-30-2019, 11:33 AM | #21 |
2589
Rep 2,432
Drives: 2021 M2C
Ok, looking at the manual it states for first 1,200 miles, do not exceed the maximum engine and road speed and don't go above 4,500rpms. Avoid full load or kick down under all circumstances.
Easy enough right? I've already gone past 4,500 a couple of times but I'm sure that's ok. |
03-30-2019, 12:15 PM | #22 |
1599
Rep 3,748
Still just wondering if BMW or other manufacturer should do the break in period at the factory ... REALLY.... come on who has time to break in drive for 1200 miles. SERIOUSLY
