03-28-2019, 05:30 PM | #1 |
242
Rep 765
do I need to recharge my A/C?
So my car recently, maybe 2 weeks ago, started blowing warm air instead of cold. it still blows warm/hot when wanted. I recall a foul smell coming from the A/C around the time it stopped working but only for a few minutes, don't know if that is a symptom of anything though. one last thing that may be related is I also recently had a GFB DV+ installed, and if their is air in the cooling system, would no cold A/C be a system? car runs perfectly fine, it is a 2013 335i. Thanks!
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
03-28-2019, 06:19 PM | #4 |
242
Rep 765
I've seen some recharge kits with sealant+UV dye, is that worth a shot? I'm hoping the sealant will take care of it, and if not I will at least know what I'm getting into before having to take it into a shop if it needs something done.
03-28-2019, 06:27 PM | #5 |
2358
Rep 2,964
I'm sorry I don't know enough on those items to give you meaningful advice - just wanted to try to help by letting you know if your a/c is low there is a leak, we all (well those of us over 35ish) grew up with having to recharge a/c on occasion as normal but that simply was because over time the systems leaked | shouldn't be the case anymore
03-28-2019, 06:58 PM | #6 | |
242
Rep 765
03-28-2019, 07:05 PM | #7 | |
806
Rep 1,906
Although all a/c systems are sealed/closed-loop, it's not uncommon over a period of several years that the system will leak a little, lose some refrigerant. You're into a hour shop labor to evac & fill. This may be all your car requires. Leave this job to the pros. |
ajob456.00 |
03-28-2019, 07:19 PM | #8 |
242
Rep 765
the recharge kit has a gauge right on it so I don't over pressurize it, and has oil. I will look up the recommended PSI though, because the range in green is "25-50", I imagine ~35psi should do it (I wouldn't do 50), but I will double check.
03-29-2019, 10:35 AM | #10 | |
772
Rep 1,502
Regardless, I’m curious to hear the results so do report back if you go ahead with the DIY. Your plan to stay on the low side of the range is a good one. |
03-29-2019, 10:42 AM | #11 | |
2589
Rep 2,432
Drives: 2021 M2C
03-29-2019, 10:58 AM | #12 | |
242
Rep 765
I didn't buy CPO, but I did buy a used car warranty that covers everything except wear items, I'll have to check if this is covered, it should be. it being a car from the east coast and showing some signs of corrosion I imagine it's a washer/o-ring at one of the joints, so I'm hoping this simple fix will take care if it. I don't want to wait another week or 2 before I'm able to take it somewhere. but like I mentioned in previous post, it worked last night so I didn't have to try it yet.
03-29-2019, 01:08 PM | #13 |
806
Rep 1,906
Best of luck. There is more to a/c than simply knowing the suction pressure via the gauge. I still feel you're better off leaving this work to a mechanic who has all the proper tools for the job.
03-30-2019, 11:51 AM | #15 |
2589
Rep 2,432
Drives: 2021 M2C
03-30-2019, 12:08 PM | #16 |
242
Rep 765
if it wasn't blowing at all I would but if it's something I can fix myself I will try. I'm not a mechanic, but I grew up working on cars and the internet is a god send for the DIY guy. funny thing is it started working again, so I can hold off for now. thanks again guys!
