03-26-2019, 06:40 AM | #1 |
2814
Rep 3,696
Michelin PS4S - BMW Star Spec - 255/35/19
I just wanted to point out that Michelin now has a BMW Star spec 255/35/19 PS4S available: https://www.tirerack.com/tires/tires...XLV3&tab=Specs
I don't know the exact differences b/n this BMW Star spec and the regular version, but often times the car manufacturers will ask for a different tread block pattern or a slight variation in width for the same size tire to better suit their cars' specific suspension, wheel, and handling designs. I'll ping Michelin & Tirerack to see if I can get an answer, but if anyone knows or can compare a regular 255/35 PS4S to the 255/35 PS4S BMW Star spec, please let us know! Last edited by ZM2; 03-26-2019 at 07:28 AM.. |
03-26-2019, 07:57 AM | #2 |
163
Rep 1,053
It isn't offered in the 275 size which most people would pair up with the 255. I guess that's why I wasn't offered that as an option yesterday when I ordered a set of mps4s from tire rack that will arrive today. I guess they don't mix and match.
I don't know the difference though. |
ZM22813.50 |
03-26-2019, 08:05 AM | #3 |
2814
Rep 3,696
Yeah, TR won’t mix/match with Star/non-Star, even tho it’s no big deal. There’s generally not a huge difference bn Star/non-Star, but it’s always good to know the specs and make your own call.
For instance, I think the last 255 PSS Star had larger channels for water than the reg PSS. That’s not what I’d want from my PS4S. Altho, the 295/35/19 BMW Star was designed to fit 10” wheels, so that’s a good thing if you want that tire and size. Who knows how Star’s impact all the different setups we’re each running, but I’ll try to get the specs so we can each decide on our own. I’m thinking they’ll come out with a 275/35/19 PS4S Star, but not quite sure. Probably depends on what tire they’re spec’ing for the next M3/4. |
03-26-2019, 12:26 PM | #4 |
2814
Rep 3,696
Lame answer from Michelin. I'll see if I can get more from them:
"The compound is slightly differently and that would affect the handling and performance. That Star means that tire has been approved by BMW. Also to get into the specifics of the tires that would be considered proprietary information and not given." |
03-26-2019, 01:52 PM | #5 |
2814
Rep 3,696
And, shot down by TR:
"When a tire manufacturer works in collaboration with a vehicle manufacturer to produce a spec tire by tuning a tire already on the replacement market like the PS4S, any changes that are made internally to the tire beyond what a standard spec sheet will tell you are proprietary information between the tire manufacturer and the vehicle manufacturer. They do not share specifics on changes for OEM tuned tires, so the only way to get an answer to that question would be to know an insider engineer at Michelin or BMW that would be willing to break secrecy and give you the details. We do not even have that info." I figured they wouldn't know. I'll try my BMW contacts. If you guys have any, ping them. |
03-26-2019, 06:17 PM | #7 |
163
Rep 1,053
One problem I can see is that if there is any material change that could affect driving dynamics from the standard ones, it would not weigh much on the overall reviews (since they are combined between star spec and not). I am not sure I would simply take BMW's word that this is better as they could have gotten it wrong. I do however trust overall tire rack reviews and ratings.
03-26-2019, 06:27 PM | #8 |
2814
Rep 3,696
Yeah, if it’s simply a compound difference, who knows what the performance difference will be like without driving them back to back and over many miles.
If it’s a clear tread pattern difference (more/less water groves), that would certainly be noticeable. To correct what I mentioned earlier, I was thinking of the Mercedes spec 265/35/19 PSS that a lot of M3/4 guys run upfront that has wider groves for rain. Again, not what I’d want, but it was designed for a 9” wheel for anyone that wants to run that upfront. I’ve been running a regular 265 PS4S on the front OEM wheels for a while, and while the grip is great, I don’t like the turn in. So, will be going back to 255. |
03-28-2019, 06:57 PM | #10 |
394
Rep 1,519
Do you think the turn-in suffers because the 265 is a bit too wide for the width of the OEM front wheel, causing some shifting of the tire on the wheel or decreasing overall stiffness/crispness? It would be interesting to compare with a 265 front tire on a 0.5" wider front wheel.
Past: E46 330Ci, E60 545i, E60 M5, E90 M3
Present: 2020 M2 Competition, 2022 GT3 |
03-28-2019, 07:39 PM | #11 | |
2814
Rep 3,696
03-28-2019, 08:32 PM | #12 |
394
Rep 1,519
Good data--thanks. When I had an E90 M3 I ran a 275/35-18 track setup all around on 18x10 wheels. It was fantastic.
ZM22813.50 |
04-11-2019, 07:43 AM | #13 |
2814
Rep 3,696
Some of the M3/4 guys are helping out on this (some aren’t). Bottom line, we don’t want to use the new 255 Star Spec 4S:
https://f80.bimmerpost.com/forums/sh....php?t=1602752 |
JTO245276.00 |
07-11-2019, 10:54 AM | #15 | |
2814
Rep 3,696
If you're a the limit, 255/275 will provide more lateral grip, and the 275 gives a tiny bit more acceleration grip. 245/265 is better in heavy rain, tho. I run 255/285. That gives me the best mix of at limit grip on the OEM wheel sizes for my tune. |
JTO245276.00 |
07-11-2019, 11:13 AM | #16 | |
2089
Rep 3,006
I have the MP coilovers. Do you know if the 255/285 rubs w/o excessive camber? I didn't see a definite answer in the threads that I have read. |
07-11-2019, 12:03 PM | #17 | |
2814
Rep 3,696
If you're at 20mm with the more stiffly sprung MP's, I think you'd be right on the edge of rubbing or not, assuming you aren't loaded down like I mentioned. I'd bet it'd work, tho. |
omasou2089.00 |
