03-25-2019, 08:59 PM | #1 |
8
Rep 36
Buzzing sound...normal?
I just starting hearing this buzzing sound. The car was cold, drove it for about 5 minutes.
After I heard the sound, drove it for another minute, and it went away, couldn't replicate it. But likely to come back... Something to worry about? Any thoughts would be appreciated |
03-26-2019, 02:22 AM | #2 | |
161
Rep 446
definitely get it checked
Mod bug will bite you if you buy a BMW ================================= |
03-26-2019, 12:38 PM | #4 | |
8
Rep 36
I scheduled a 55-pt. inspection next week with the dealership, at which I will address this issue (along with an issue that I am having with the clutch/transmission when the car is warm). But it would be great to have some insight before then so that I have an idea of what I am talking about... |
03-26-2019, 01:03 PM | #5 |
125
Rep 298
Which engine and which year? Try to blip the throttle a little bit when you have the sound and see if it goes away. If yes to that, early N55 and if the sound comes from the turbo direction it can be the boost solenoid.
https://www.youtube.com/watch?v=IYt8fLTzh_U |
03-26-2019, 02:13 PM | #6 |
8245
Rep 16,086
Sounds like a B below middle C to me, more of a hum than a buzz. That rules out the usual suspects. Does the pitch change with engine speed?
03-26-2019, 03:25 PM | #7 | |
8
Rep 36
Maybe something to do with the waste-gate solenoid? |
03-26-2019, 06:32 PM | #8 |
1307
Rep 1,827
I have a similar intermittent buzz coming from my pwg N55. I've read it could be the boost solenoid, apparently also called the turbo pressure converter. The replacement part for my car is about $160. Thinking about just replacing it, partly as preventative maintenance, partly in hopes it eliminates the buzzing.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
03-26-2019, 06:33 PM | #9 |
1307
Rep 1,827
Weird buzz sound on passenger side on engine bay https://f30.bimmerpost.com/forums/sh....php?t=1563523
ig19838.00 |
03-26-2019, 08:33 PM | #11 | |
8
Rep 36
Thanks! |
03-27-2019, 07:40 AM | #12 |
125
Rep 298
In my experience the boost solenoid buzzing occurs as the revs drop to idle. So once engine is warm so that it has the normal low idle revs then give throttle a short tap. As it then returns to idle revs it sometimes starts buzzing and sometimes not.
03-27-2019, 08:54 AM | #13 |
8245
Rep 16,086
That's why I asked if the pitch changed with the engine revs. It would go up and down with the revs if it was mechanical, but would probably stay constant if electrical.
03-27-2019, 09:18 AM | #14 | |
8
Rep 36
If it comes back, I will certainly check whether the buzz/hum changes with the revving of the engine. |
03-27-2019, 12:05 PM | #15 |
8245
Rep 16,086
If it's serious it should show up on a scan with a good quality OBD diagnostic tool. Once out of warranty you really should have one, not only to know when you have a problem but also to know when you don't. Mine paid for itself the first time I used it.
http://f30.bimmerpost.com/forums/sho...2#post23288222 |
03-27-2019, 12:50 PM | #16 | |
8
Rep 36
https://www.amazon.ca/Diagnostic-FOX...gateway&sr=8-1 |
03-27-2019, 01:14 PM | #17 |
8245
Rep 16,086
I have the NT 510, the NT 520 is a newer version but the only advantage to it is it can store data for more car brands. If you have trouble with it go here:
http://www.foxwellsupport.com/tag/foxwell-nt510/ |
03-28-2019, 10:43 AM | #18 | |
5886
Rep 10,256
By the way, did the dealer share any details about any stored codes? |
03-31-2019, 07:45 PM | #20 |
8
Rep 36
Update: heard the whirring/buzzing noise just now; started as I was slowly backing up, continued as I was idling; I revved the first time, it went away; I revved again, it came back, but slowly dissipated; I revved again, and it came back, and slowly dissipated etc.
I'll update after my 55-pt. inspection this week. |
04-10-2019, 05:18 PM | #21 |
8
Rep 36
Dear all,
I am posting another video of the sound. It is becoming more frequent. I have located it on the passenger side of the engine (please see video). The sound does not get louder or softer with engine revving. It will generally go away once I rev. As always, all comments are much appreciated. |
