03-24-2019, 04:38 PM | #1 |
Rep 14
n55 Valve Cover or Oil Filter Housing Gasket - using sealant to prolong life
Due to high oil temps, these get cooked, brittle, and crack insanely fast. In order to prevent ever having to do it again, has anyone used any gasket sealer, RTV, shellac, aviation sealant, etc. on the oring-style gaskets to help keep them sealed up when the rubber eventually fails?
Not looking to start a debate, its a poor design that is quoted over $2000 to fix. Im going to do it myself, and to prevent having to do it in another xx,xxx miles, would like to understand if anyone has done this, what they used, and with what success. Thank you! |
03-24-2019, 07:49 PM | #2 |
302
Rep 526
the dealership quoted you $2000? or a independent shop?
Parts for VCG: $200 or so and labor is 4hrs. so should be around $600 or so. I got mine replaced under warranty thankfully. |
03-24-2019, 08:07 PM | #3 |
989
Rep 2,200
Local dealer quoted me $1800 to replace the valve cover gasket, including an associated hose. Turns out the cover was warped at 45K miles.
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining |
03-24-2019, 09:17 PM | #4 | |
153
Rep 258
Forgive me if that's the average of what dealers charge, but that's an awful lot of money for a valve cover gasket replacement. My first car was a VW Bus and the gaskets cost about $2.50 and you replaced them at every oil change. |
03-25-2019, 08:39 AM | #5 |
Yoda of mods
1675
Rep 3,006
Drives: X5 RWD
Current: 2020 Explorer ST (Agate Black Metallic), F15 SGM RWD
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired) Follow me on Twitter: https://twitter.com/EdwyerCLT YT: https://www.youtube.com/@DWYERGARAGE/videos |
03-25-2019, 08:47 AM | #6 | ||
806
Rep 1,906
03-25-2019, 03:39 PM | #7 |
989
Rep 2,200
Correct. Needless to say, they won't be doing the job!
03-25-2019, 05:02 PM | #8 |
1999
Rep 2,499
I wouldn't use RTV. The initial seal is fine and I feel like the degradation of the seal would occur whether or not you used RTV.
Also, over $2000? Is that with a new valve cover? If your car is out of warranty, there is zero reason to go to the dealership for this work. You're just throwing away your money. I'd just do it myself without RTV. Are you even going to own the car long enough to have to do it again in about 75k miles? |
03-26-2019, 08:43 AM | #9 | |||
153
Rep 258
I think labor cost of replacing entire valve cover vs only the gasket would be the same; maybe there are a few odd and ends you need to transfer from old valve cover to new. So, I still don't see this exceeding $1,000, even at a garage that serves espresso. |
03-26-2019, 11:29 AM | #10 | |
1999
Rep 2,499
03-26-2019, 04:08 PM | #11 |
192
Rep 540
My mechanic replaced my N55 V/C last month. This is the list of parts. It was $1,000 OTD. He recommended to replace the hose and seal at the same time, no extra labor. He has 14 years of experience at the BMW dealer and opened his own shop 6 months ago.
11127570292 N55 V/C 1.0 @ 539.14 =$ 539.14 11367609963 Valvetronic Screw 2.0 @ 0.99 =$ 1.98 11127599753 Vent Hose 1.0 @ 61.26 =$ 61.26 11377502022 Valvetronic Seal 1.0 @ 9.89 =$ 9.89 |
03-26-2019, 05:13 PM | #12 |
Rep 14
Who cares what the shop costs, because as stated in the OP I am not going to have them do the work. For everyones sanity, that was for VCG and Oil filter housing seal.
Im interested in finding out if anyone has had success using non-hardening sealant such as Aviation sealant on either the VCG or OFHG to help keep rubber sealed to surfaces once it gets brittle and cracks. Thank you for the suggestion on the seal, ill replace that, but not the hose unless I break it. If I do, Ill cut off and replace with heater hose. Have had to do it a TON on my Cayenne. |
04-28-2021, 10:57 AM | #13 |
471
Rep 1,268
My rocker cover gasket & oil filter housing gasket got replaced at 52K under warranty too.
They did throw in a cheeky £100 charge to change a 'brittle' coolant line which must have fell apart when doing the above work. Grrrr |
