03-23-2019, 12:32 PM | #1 |
Regular user
224
Rep 965
Drives: F30 330D M-Sport Auto
Can Bimmercode keep the reverse camera on?
I read a thread how Esys or similar could code the rear cam to stay on when you drive off. Can this be done with Bimmercode even in Advanced mode as I would find it useful to see what I'm towing.
03-23-2019, 03:01 PM | #2 |
8245
Rep 16,083
I doubt it, as even with E-Sys you have to use some non-standard coding to do it. You have to code not only the speed at which the camera shuts off but also the distance traveled.
03-24-2019, 02:26 AM | #3 |
13347
Rep 7,484
In Bimmer Code there are two things you could code on the REM unit.
Rear view camera speed switch off. Code to 50 km/h Rear view camera distance switch off. Code to not active. Camera would stay on up to 31 mph / 50 km/h May be under expert mode a custom value could replace 50 km/h if you intend to tow above that speed. You would need to manually activate the cam each time then drive off. |
