BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    Anyone on here with RE71R or R888R with pics?
      03-22-2019, 03:35 PM   #1
BigMacSmallFries
123
Drives: '19 M5C 911 Turbo F430 GT3 RS
I'm looking to get a square set up year round, and I like that beefy summer tire look.
The widest tread width that exist for our cars in 285/35/20 is the RE71R where the 285/35/20 is actually wider than the average 295 tire, and the R888R (obviously the R888R overall is not a good idea for a street tire) where the 285s are almost identical to the average 305 tire.
Is there anyone here that has successfully installed either tire on their car with 11/12mm spacers?
Would be great if you could post some pics!
shawnhayes1829.50
      03-31-2019, 12:08 PM   #2
shawnhayes
1830
Drives: 22M5 CS,23X5E,24M3 CS,24 i4
Here's the right front with r888r's square
      03-31-2019, 12:09 PM   #3
shawnhayes
1830
Here's a quarter shot:
      03-31-2019, 12:16 PM   #4
shawnhayes
1830
Two pics. bimmerpost app having trouble uploading from camera. Anywhere you'd prefer me to upload the pics to? They're on my iphone.
Shawn
      03-31-2019, 06:28 PM   #5
BigMacSmallFries
123
Wow, so you have R888R all around? Are they on OEM 20"? Do you have spacers, do they rub?
Thanks! No clue where you can upload them, maybe someone can chime in?
      03-31-2019, 07:52 PM   #6
shawnhayes
1830
Here ya go I hope.
      03-31-2019, 07:54 PM   #7
shawnhayes
1830
R888r's all around on OEM wheels. 285/35r20. No spacers.
No rubbing.
Track next week. The stock Michelins lasted six track days. These will be much stickier. We'll see how long they last.
Shawn
      04-01-2019, 12:22 PM   #8
BigMacSmallFries
123
No rubbing.
Shawn
Wow, damn, I need to know if it's possible to throw 11mm spacers front and rear with these, I highly doubt the rears will clear but damn that looks aggressive!
      04-01-2019, 12:30 PM   #9
shawnhayes
1830
My guess is that on hard bumps they would rub in the back. I don't think they'll tuck.
Shawn
      04-10-2019, 07:55 PM   #10
shawnhayes
1830
These tires were good and fairly sticky for the first three hours on track...
Pressures were hard to regulate. These heat up A LOT. Had to put the starting pressure low to get to the recommended 35 psi hot that Toyo recommends. They still fell off after THiS happened:
      04-10-2019, 07:57 PM   #11
shawnhayes
1830
Hard to keep grip at 190 F tpms temp.
Maybe should have kept them at 39 psi hot. Maybe.
Shawn
      04-12-2019, 08:37 AM   #12
BigMacSmallFries
123
Installed RE71R no rubbing at all with spacers. Crazy how close it is though, prob 1-2mm max from rubbing. Looks really aggressive too.
      02-29-2020, 06:16 PM   #13
gtenedio
Drives: '%E2%80%9909 e92 m3, '19 X3, %
Shawn
any further feedback on the r888's for track use?
what PSI do you recommend
      03-22-2020, 08:32 AM   #14
shawnhayes
1830
They were very sticky at first (just like all R888's) but fell off with multiple heat cycles.
Need to aim for 35 psi HOT. This was hard to keep consistent.
Other problem - they were LOUD. Randy Pobst went out of his way to come to my garage thinking I had a differential problem. It was just the tires. They make a very ugly high speed whine that sounds like gears going bad.
Shawn
